Question about Thermador C272 Electric Double Oven
After a power outage the oven stopped working and CAL appeared
    Scholar:
  • 64 Answers
You need a surge suppression device on the oven...It is hard to do that so were do you put it. On the main distibution panel.
Not a lightning Arrestor. It is not a Surge suppressor. A lightning arrestor only keeps the wires from burning up, and a surge suppression deivce not only does that but keeps your stuff from blowing out like it did.
PTS-240HUL-L will cost you $268.00 and I have one in stock.
A electrician will cost you $50.00 in a non-union state and in a Union state about $100.00 to do the install...if you sweet talk him into it.
www.storminprotection.com
Posted on Sep 11, 2009
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Aug 25, 2009 | Electrolux EW30EW65SS Stainless Steel...
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador C272 Electric Double Oven Logo
251 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
