RCA 52'' Projection HDTV Blue ''ghosting''
I have an RCA D52W25 HDTV. All pictures have a blue ghosting effecting. It looks like shadows of the images, always in blue, no matter what the color of the image. Tried to fix with convergence. You visibly see the Red and Green Test, but nothing for the blue. Continues to get worse (originally localized to remote areas of screen.
  • 1 more comment
  • sbdeals Dec 11, 2008
    Re: Clarification Request:
    Not sure how to test the resistors.  I do amateur repairs and need to determine whether to call someone...and if call how much should I expect this to set me back?
    Re: Solution #1
    The convergence is on the menu and I have tried it several times.  It test red and green visibly and no square pop up when it switches to blue.
  • jason May 11, 2010
    this could be a resistor or a convergence IC failure ,
    can you test the resistors for thier values?
  • 5,138 Answers
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Posted on Dec 11, 2008
  • ladywinn
    ladywinn Dec 11, 2008
    you can order complete deflection board for 197.00 ,if you can fix problem your self fuse 1.00 at most 5.00 call UED 1-800- 648-6657 they have boards.I have Fixed alot of these TVs.
  • 905 Answers
Well this can cost between $300 - $400 to have them come out to your house and do the repair
  • jason Dec 11, 2008
    but check around and see if you can get a better estimate on the repair and service call so you can get the best deal
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Help!! The Image on the Television is ghosted and distorted!
This is a convergence problem that will continue to get worse. I repaired a few of these recently and found that the main problem was poor/broken solder connections at the flyback transformer. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
That being said, the flyback needs to be resoldered and the pico fuses close to it need to be checked and replaced should they be open.
The parts cost for this (even when replacing the 3 pico fuses) should not exceed $10.
Dan
May 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
Aug 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca look like 3d picture
You have a convergence problem. The Red and Blue are out of convergence meaning they are out of synch, causing shadows. There should be an Auto convergence option either on the television or through the menu options on the remote. If this doesn't fix your problem, then there's a manual convergence option. Should that fail, a service call is in order. Best of luck!
Greg
May 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Rca 52" hdtv
unfortunatey that diagnoses sounds correct. sorry when the "glycol leaks " it cause all sorts of damage. in theses sets the tubes cost about 250 a peice. plus very labor entensive to replace. these "value" sets cost about 800 new at your local walmart.
May 19, 2008 | RCA D52W19 52" Rear Projection Television
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
