Question about Memorex MVDP1102 Portable DVD Player
DVD player - Memorex DVDP 1102 - "NO DISC" message
My son just received his DVD player - Memorex DVDP 1102 - and he touched the lens and now it will not read any DVD cds. It reads "NO DISC" when you put a DVD in. Please help - it's his favourite companion. Many thanks in advance.
  • miss_steer Dec 11, 2008
    Hi Drumbanger:
    thank you for responding but the tip didn't help. I wipe over and around the lens, then gently tried to raise the lens. I also dropped it on a soft pillow. Please.... am I missing something?
  • bjhunter412 Jan 14, 2009
    I also am having the same problem. My daughter might have touched the screen. I was looking at the time. It shows no disc. I have tried everything I know. Please help.
    bjhunter412@aol.com
    Genius:
  • 1,199 Answers
Ok get a cotten swab and put a little alchohol on the tip now gently rub over and around the casing of the lens...gently trying to lift it back up into posistion (your son pushed it down into its casing....You might also try droping it upside down on a soft couch pillow to dislodge the lens (This method has worked for me ) ps its just a hair!
Posted on Dec 11, 2008
Dvd won't play my dvd's. keep saying no disc or wrong disc. what is the problem
  • Hi, Sounds like the lens is just really dirty. Go buy a leans cleaner disk and run it through the DVD player two or three times to get the lens good and clean. Repeat about once a month to keep the lens clean and running properly. Sometimes you need to run it through 3 or 4 times to get the lens to read again.
  • These disks I speak of have little bristles on it that "sweep" the lens clean. I use them on all my disk players and they work real well.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 26, 2011 | Memorex MVD2016 DVD Player
My memorex DVD player doesn't read the discs anymore. I cleaned the laser with alcohol and and a cotton swab. It will spin the disc for a while and then will say no disc. It's not the discs because I...
If you already tried to clean the laser lens and that did not work, it seems like the lens is defective. This product has a 90 day warranty so you'll need a copy of your proof of purchase in order to get a warranty replacement from Memorex.
Dec 29, 2010 | Memorex MVD2040 DVD Player
The dvd player just says it is loading and never plays the disk
The reason your player keeps reading a disc but do not play it is either the lens is weak or dirty.
To fix it if it is dirty, all you have to do is to clean the lens with a lens cleaner.
To fix it, if the lens is weak,
  1. Get the appropriate screwdriver,
  2. Unscrew the cover of the player and remove it,
  3. Unscrew the disc tray, you will have access to the lens,
  4. Get a new lens and replace the lens,
  5. Reverse the process to reassemble the player.
  6. Test it with a DVD disc.
Take care
Jun 20, 2010 | Memorex MVD201 DVD Player
"Wrong disc" memorex dvd player error
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
Mar 02, 2010 | Memorex MVD2042 DVD Player
My DVD Pler loads but in aminute or so it says no disc
Try another disc, does this happen with all discs? the optics are most likely failing, did you try a DVD lens cleaner and also try canned air?
Mar 08, 2009 | Memorex MVD2042 DVD Player
Installed memorex mvd2042 dvd player, receive message "root"
Aha. I just found a solution. Press DVD menu on the lower left.
Dec 29, 2008 | Memorex MVD2042 DVD Player
My Memorex MVD2042 Progressive Scan DVD player says no disc
the lens is located on the inside. you will have to remove the top casing, once you do you will see the dvd player, then you will need to remove the top bar that runs across it. you will see a yellow sticker on....undo the screws and the you will see the lens.....
Nov 16, 2008 | Memorex MVD2042 DVD Player
Dvd player bad disc message
your dvd head (lens) is bad
(1) it needs to be cleaned by a special fluid puted in the cleaning disc or
(2)it needs to be adjusted because it lit vey low illumination (light) during detecting the details of the disc. and this need a qualified technician ot adjust the variable resistor port attached in the lens assembly unit.
Sep 08, 2008 | GPX D1816 DVD Player
JUST RECEIVED DMR-ES15 RECORDER. WILL NOT PLAY RECORDED DISC, GIVES "NO READ" MESSAGE.
Turn off for half hour and then try it.....If u have warranty then claim it...
Jul 02, 2008 | Panasonic Televison & Video
My dynex dx-pdvd7 is showing "no disc"
If there is no little circle eye near the center of the spindle-you are out of luck. If you can see the lens it may be just jammed. Simply, gently, slide the eye along the track back to the spindle. That usually fixes it.
Jun 24, 2008 | Dynex DX-PDVD7 Portable DVD Player
Memorex MVDP1102 Portable DVD Player Logo
469 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
