Question about Garden
Trouble with Poulan 2150 Chain saw automatic chain oiler
I have a Poulan 2150 Chain saw. The chain oiler is pumping too much oil. Is it a gear driven oiler or a pressure oiler, and is there any adjustment for it. Thank you
  • mp6814 Mar 11, 2009
    Hi - similar problem - I run out of oil before gas, clearly a dangerous situation. Any advice as to how to run out of gas first? I.e., how to lower oil flow?
    Thanks,
    Marek
The tube to the the oiler metering valve is probably broke open. This happens with age. Replace the tube by cutting tube on sharp angle and push through the oiling port. using needle nose pliers pull tube in enough to cut and attach to the metering valve.
Posted on Jan 30, 2013
Thanks, guys. Right, I do fill it partially now, but it's annoying. Oh well, there is no simple way to restrict the line - I have disassembled the unit and one would only hope the designers would think about a simple device for adjusting oil flow, but there is none. Primitive, since oil will flow at very different rates in cold and warm weather...
Posted on Aug 16, 2009
  • 211 Answers
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Posted on Dec 15, 2008
Top off the oil, but only fill the fuel level about 3/4 to the top.
Posted on Jun 10, 2009
  • 4 Answers
Restrict line somehow?
Posted on May 04, 2009
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Poulan 2150, chain oiler not working. Chain is getting very hot.
Try to pour some gasoline only in the oiled tank and look if the gas comes out, if not the tank is clogged .
Oct 12, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No problem i want to know how big the motor is in cc's
40 CC's or 2.5 Cubic inches
Poulan, Wild Thing, 2375, 18" Gas Chain Saw, 2.5 CUIN, 40CC, 2 Cycle Engine, Vertical Cylinder Design, Dual Counterweight Crankshaft, Primer Bulb, Inertia Chain Brake, SuperClean Air Filtration System, Gear-Driven Automatic Chain Oiler, Full-Wrap Handle
Mar 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need remove the clutch on my 2150 poulan pro chain saw, so I can fix the chain oiler.
Good film. Make certain the piston is above the exhaust port or the rope can fall through and damage the piston above the piston ring. When started it comes apart and destroys the saw.
The oiler worm gear is behind the metal cover visible once all clutch parts are removed. HTH
Lou
Jan 02, 2010 | Garden
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have a MAC 3818 chain saw it just stopped oiling.
Same for me. Take chain off and ensure clean oil hole and channel. Clean hole if needed with fine wire or heavy nylon line. otherwise I think problem is interior, either oiler itself or oiler oil tube came loose. Since I have no excess oil coming out I suppose oiler iself is bad.Still working on it.
Apr 17, 2009 | Poulan 1630 16" Chain Saw
Garden Logo
1,679 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
