Question about Ruud UAMB Air Conditioner
Ruud urgh07e36jkr heater wont turn on
My heater wont turn on and under the front cover I hear a loud repeating click . The ac and fan work ok.
Well I checked and the pilot would light and then go off right away and repeat.I jumped the 24v terminal to the pv pilot valve terminal on the ignition module and the main burner lit up. I then disconnected the spark igniter and the burner shut off and it tried ti relight producing hi energy sparks from the ignition module. So I ordered the module from american hvac parts online and replaced it. I recieved an updated module and had to hook up the 24v to the th-w terminal to make it work the old module was a s86ooh
And i just searched the new model number to figure out how to make it work. The new one has self diagnostics on it. It cost 208$ with shipping
Posted on Dec 22, 2008
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
2000 acura tl ac heater fan wont turn on
my acura tl fan turn on when i turn on air conditioning why
Aug 22, 2012 | 2000 Acura TL
Fan for heat and ac wont blow air. Makes A loud clicking sound
mcdevito75 here, The heater/Ac fan motor is a sealed unit, locate the fan motor, as you look at the engine from the front of the car the fan motor will be on your left side comming out of the firewall, It"s a round cylinder like and is black, from inside the car put the fan on, tap the fan motor itself with a screwdriver, small wrench, etc. see if it"ll start, if not have your local shop replace this fan motor.
Jul 05, 2010 | 1999 Ford Taurus
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
Ruud ac wont come on. mfg 03/99. thermostat
Have an electrician check the connections in your panel, this sounds like a loose/bad nuetral connection
Jul 26, 2009 | Ruud Heating & Cooling
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot....
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
May 27, 2009 | Ruud Handle Air Conditioner
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
R = Red One Side of 24 volt Transformer
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
Heater work when switch to fan on but doesnt work when swithed to auto but the ac works on auto or on, conufused please help
When switched to on does it make heat or is ir just the fan blowing? Take the first cover off the thermostat and see if there is a jumper wire from RC to RH. If not you need to add one. Also, the heat doesn't come on instantly like the A/C, it takes a couple of minutes for the pilot to lite, the burners to come on and then the time/temp delay relay will click on the fan motor, this may take a few minutes.
Dec 16, 2007 | Ruud Handler Air Conditioner
Ruud UAMB Air Conditioner Logo
89 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
