Question about Microwave Ovens
I have a microwave with the model# JES1288SH01 and everything works fine but it make a small weird nose and does not heat anyhting up. Is there a serious problem and how can it be fixed?
  • jason May 11, 2010
    it is a problem that a shop will have to fix ( magnetron ) , therefore I will not be able to fix this over the internet , or get a fixya out of it , so it would be your best bet to call a shop if you think it will be worth the repair cost
  • Microwave Ovens Master
  • 9,098 Answers
Tons of people follow the basic safety rules and repair their own microwaves every year.
With a little expert assistance, it's not too hard.
When you hit Start to cook, do the inside light and turntable come on?
Is the noise a louder than usual hum or buzz?
If that's what the noise is like,
I would most strongly suspect a shorted high voltage rectifier diode, a bad magnetron or possibly a bad high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 13, 2008
Ge micowave browing oven (JES1288SH01) want heat up anything everything else work and i smell something burning when turn on
If it is louder than usual, you probably have a shorted high voltage rectifier diode.
If it's not louder than usual, you probably have a defective magnetron or high voltage transformer.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
Oct 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works on my microwave but it want heat anything. Lights, Vents, and Fans all work properly. There are no weird noises or anything, whats the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Whirlpool WMH1162XVS Microwave Oven
Microwave will not heat
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating was fine then not?????
It could be an internal fuse, but these fuses are very high rated ( typically 5kv 8amp) and should be fitted by a qualified technician only.
Jun 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
Microwave fan won't turn off?
hi i would think that the power problem has fried the processor
cheers grant
Oct 23, 2008 | Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
