Question about RCA Lyra RD1021 MP3 Player
Won't turn off with stop button have to take out battery
Everything else works fine. the stop button "clicks" as if it is working, but just won' stop.
    Problem Solver:
Used compressed air and lightly blew dust from around and under controlls. works fine now. code 3
Posted on Dec 11, 2008
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
Car won't turn on; clicking sound
It does sound like a starter problem but the easiest way to rule that out is by trying to jump start the car with a push , if your starting motor has packed in it will still start with a jump start
Feb 24, 2013 | 2008 Hyundai Elantra
I just had my brakes changed on my 2006 passat. Now the electronic parking break sensor won't stop beeping but everything works. How can I get the fault to go away so It will stop beeping
also if u take battery off for 10 mins, hook battery back up again, turn car on, hold in break paddle for 35 seconds, then still holding in break paddle hold in handbrake button for 10 seconds, release all and start car up, press break button a few times, turn car off again take out key, lock and open car then press break button again and now all should b back to normal
Mar 27, 2012 | 2006 Volkswagen Passat
Hey I have a 91 cb lancer I turn the key to on then to start and all I hear is a click why won't it start what could be the problem
When you turn the key to the "on" position, see if the panel lights come on and try honking the horn too, if everything works it means the battery is fine.
Now, turn the key to start the engine. Does the engine just give out a click? If so, the battery terminals may be loose. Tighten the terminals leading to the battery posts with the correct tools and try turning the key once again.
Nov 03, 2011 | 2002 Mitsubishi Lancer
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
Car was working fine then i went out again it started then cut off and now won't start everything's fine only thing went wrong power windows stopped and power windows stopped working also before...
Sounds like possible fusible link is blown or lose?
Fusible links are different then regular fuses found in fuse box and are located under the hood near the battery ..
Did you just install the system ? or has system already been installed for a while and this problem just occurred ?
May 15, 2011 | Car Audio & Video
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
RCA Lyra RD1021 MP3 Player Logo
88 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
