Toward the end of a wasing cycle there is a tremendous squeaking noise. What might that be? I thougth maybe the pump but then when it was draining the soapy water it would happen too. I noticed it last time while it was draing the rinse water. Thank you. Ben
  • Washing Mach... Master
  • 3,463 Answers
If it only happens when it is draining then there is a problem with the pump, could be something fast in it, remove pump and check., or if it is there all the time then it is to do with the motor or the drum..
Remove belt and see if the noise is still there, if it is then it is your motor'
Plz rate this solution.
Thanks.
Posted on Dec 11, 2008
Fisher and Paykel EcoSmart GWL15 won't drain at the end of it's cycle. I put it in diagnostic mode and the got it to drain that way. I ran another cycle and it wouldn't drain on it's own again. Put it back...
Hello Robert. If you have heard any kind of squeaking or squealing or rattling while the pump was running, replace the pump. You mention a humming noise. Also a sign to replace the pump. When FP pumps fail, they will not spin at the correct speed and that is why when you run it in diag mode you can pump out the water as it runs until you stop it, but will not drain in a normal cycle. Be VERY careful when you replace the pump. Make sure you get no water in the new pump windings when replacing the pump or you will WILL take out the machine controller. Pump p/n is 479595
Apr 09, 2014 | Fisher Paykel EcoSmart GWL15
The spin/drain cycle are leaving the clothes wet after wasing almost all the time.
Hi kerry_coorner,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an 'nec nw452, 4.5 kg' washing machine toward the end of the cycle an OE msg comes up and the water doesnt drain. long beeps???
Check the voltage at the drain pump/valve in the first place. Look from under the washer and use a multimeter carefully in the AC range to find the voltage when the wash is initiated to the drain cycle. If there is no supply the program controller unit is faulty but if there is supply the drain pump/valve is clogged or faulty. remove clean or replace.
Feb 05, 2011 | Washing Machines
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Water not pumping out in the spin cycle anymore
Check the drain pump and drain hoses. The drain pump is located in front of the motor. To access it, remove the end caps from the console. Remove the 2 screw holding the console to the cabinet. Pull the bottom of the console toward you slightly and flip the console up. Unplug the lid switch molex connector. Inserting a flat screwdriver from the top and pushing back, remove the brass clips on each side. Open the lid. Holding the inside of the cabinet, tilt it toward you and remove it from the base. This will give you access to everything including the drain pump and the drain hoses. Try to remove as much water as possible from the inside since it will all come out when you remove the drain hoses from the pump (hopefully you are near a drain in the floor). Remove the hose clamps and check the hoses and pump for any obstructions. Chances are, you will find a missing sock.
If it all looks clear, remove the drain pump from the motor and inspect where the pump connects to the motor for a broken connection slot. Replace the drain pump if necessary.
Mar 03, 2009 | Kenmore Washing Machines
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
