Question about Jenn-Air JED8430 Electric Cooktop
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
The front panel lights for the burners all work when I turn the knoobs to HIGH, but no action on the burners themselves. It is a smooth top, 4 burner unit. It has been working fine up to this afternoon. I did have some contractor work done in the house today ( new Peerless and Beckett burner/boiler ). They had to cycle the electrical service panel breakers on/off to identify circuits in the house. I'm not sure if something changed or is it a coincidence that it happened when the household electrical service / breaker panel was being cycled by the burner installers ? I first assumed a fuse would be a suspect but why would ther be front panel lights at all? If it is a fuse, what does it look like and where does one find this thing? Can it be tested with a continuity tester? voltmeter? Please help !!
  • 1 more comment
  • Andy DelPriore Mar 04, 2007
    Catriver, Thanks for your quick reply. I did check and found that the contractors used a second breaker and have 120v across black and white as well as red and whit on oven terminal block. Is it time for a new oven ? recommendations?
    PS: I just realized what you wrote after I sent mine. I did not read 220v ascross red and black.
    Hey Catriver, Thanks a million for your expertise, however, I found something that I wouldn't expect you'd imagine from my previous comments: Turns out that the contractor angle has been dismissed as purely coincidental. The breaker itself had water damage from a leak inside the panel and after replacing it works fine now. Thanks very much for even the comfort of knowing there is proficient help on line. Much appreciated!
    Andy
    President:
  • 878 Answers
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Posted on Mar 04, 2007
I need a left front burner for a CP 220B Jenn Air electric downdraft cooktop: Serial no 069760DM. I also need a new blower motor, I think. Possible???
This is the first result I found; it may not have the best price:
http://www.appliancepartspros.com/jenn-air-range-cooktop-oven-burner.html
The site also lists blower motors, but be sure to verify that the motor is defective before ordering; they are very expensive.
Jan 17, 2017 | Cooktops
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Great old Jenn Air range needs advice!
YES THEY USE DIFRENT SWITCHES AND IF THE 1 YOU HAVE PROBLEN IS THE DUAL BURNER THER IS A SERVISE FLACH ON IT YOU NEED TO GO TO SERVISE MATER.COM AND FIND THE UPGRATE
Jan 25, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JED8430 Electric Cooktop Logo
951 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
