Question about Carrier 38CKC042 Air Conditioner
York P3HU Gas Furnace Blower wheel makes noise and vibrates
I have an attic installed horizontal gas furnace for about 10 years. The unit has been making noise and rumbling vibration lately. I removed the blower assembly from the unit and inspected the blower wheel. It appears that the fin assembly is slightly detached from the two round dishes that hold them in place. I turned the shaft of the motor quickly and the fin assembly grinds the dish slightly, therefore making a short grinding noise. Is the fin assembly supposed to be held tight by the two round dishes? Can someone tell me if the wheel is bad or there could be other problems? If replacing the blower wheel is the solution what are the steps and cautions that I should take? Thanks in advance.
  • 96 Answers
Yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Posted on Dec 11, 2008
Can I install my gas furnace horizontally? Model FG6RA - 096C- 20C
Contact the manufacturer. This is too Important to take some anonymous persons word for.
Oct 13, 2016 | Heating & Cooling
Hi i have a york diamond heater in my attic. I went up in the attic and revomed the grill and the four burners are not coming on. it clicks and u smeal gas but it will shut off. the little blower motor...
If your furnace uses an electrical glow element to light the pilot light, the Glow Element will need to be replaced. Glow Elements are general used on 90+ High Efficiency Gas Furnaces.
If it uses a standing pilot light rather than the Electrical Glow Element, you need to manually relight the pilot. Since I can't see your furnace, you will need to locate and read your Owners Manual on how to do this or look in the side or inside the pilot light compartment for instructions on how to light it.
Be sure you have stick match or a butane grill lighter with you before you try to light it.
If it's a manual pilot ... if after lighting it, it doesn't hold when turned to the ON position, more thank likely you'll need to have the Thermocouple replaced.
And above all, BE CAREFUL. If you don't feel comfortable lighting a gas furnace, call a professional.
Feb 07, 2011 | Heating & Cooling
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
York P3HU Gas furnace blower making grinding noise and vibration
If the wheel is rubbing on the housing obviously that's no good. Yes that is one solid piece, it needs replaced. Not an extremely difficult job, toughest part likely getting the wheel off the shaft. Sand exposed shaft and use some lubricant. Before removing motor mark on the housing where the wires are located/ direction they point. Do not forget to tighten set screw upon reassembly. Good Luck!!
Mar 28, 2017 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
1,574 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
