Question about Toshiba Satellite A45-S150 Notebook
Hi there, my name is Ricky and i got a little problem. my toshiba a45-s150 kept on overheating and shutting down... so i took out the heatsink and cpu to clean it... i put it back and now my computer won't power up.. i need help
  • JDTec
    JDTec May 11, 2010
    Did you re-seat your CPU correctly. I would take the CPU out and re-seat it. Overheating then shutdowns is usually caused by a bad or intermittent fan.
    President:
  • 2,110 Answers
There might be something loose connection...try to check all the cable connection...remove and re insert RAM ...lets hope for the best..
Posted on Dec 11, 2008
WHERE DO I ORDER A HINGE FOR TOSHIBA A45 MODEL. ALSO, HOW DO I REPLACE IT?
Hi
You can purchase the HINGE of toshiba A45 online .
Please visit this website
http://www.aliexpress.com/wholesale/wholesale-for-toshiba-a45-lcd-hinge.html
and it will direct you to the page where you can purchasethe hinge .The pricing information is also available on the website/page.
Thank you
Nov 26, 2010 | Toshiba Satellite A45-S150 Notebook
I have a45-s150 and want to add memory. where does it go?
The following website explains how to add memory in detail.
http://www.insidemylaptop.com/adding-ram-memory-into-toshiba-satellite-a45/
I hope this helps!
Oct 22, 2010 | Toshiba Satellite A45-S150 Notebook
Need to remove cpu fan
STEP 1Always start laptop dis assembly with removing the battery.
STEP 2
Remove six screws securing the hard drive cover and the heatsink covers.
STEP 3
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
STEP 4
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
STEP 5
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
Runs very slow... hard disk constantly running
You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
Jan 05, 2010 | Toshiba Satellite A45-S150 Notebook
How do i add more ram
The Toshiba Satellite A45-S150 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A45-S150 can support up to 2 individual RAM modules. Look on bottom of laptop and there will be place to take screw out and you will see the 2 modulars. Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A45-S150.
Nov 28, 2009 | Toshiba Satellite A45-S150 Notebook
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Replacing the cooling fan
You can find a guide with pictures there:
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
The guide is for display hinge, but you can follow until step 20 and the rest should be easier!
Aug 25, 2008 | Toshiba Satellite A45-S150 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba A45-S150 PC Notebook
Boot the system up and hold down the‘Esc’ key, then press F1 when you get the check system message. You are then in the BIOS Setup OR press F2 after bootup. Note the method will depend with ur model.
Mar 11, 2008 | Toshiba A45-S150 Notebook
Toshiba Satellite A45-S150 Notebook Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
