Question about HP PSC 950 All-In-One InkJet Printer
Canon mp 390
Since I moved to my new place, my printer's cartilages are not moving at all. Each time I push my canon mp 390's "copy button" on the printer, a strange noise come out, and it cartilages not moving at all, and on its display shows, "check printer, press set key". Anyone knows what problem I got with my printer? Do you think might be a driving robber has got off? Any instruction for that?
  • 624 Answers
This is a duplicate post, click the following line to see the original post: http://www.fixya.com/support/t136257-canon_mp_390
Posted on Mar 04, 2007
I need a free user manual download for a Canon MultiPass MP 390
You can get check it here:
http://soft-manufaktura.ru/manual/hp/mp390sm.pdf
Nov 15, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
How to reset error e4
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Resetter
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing thisreset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′. This method takes from indoreset yahoo group and prepared by Choy.
  8. Open cover
http://downloadprinterresetter.blogspot.com/
OK, go to website above, and download a "Resetting" tool, this makes resetting easier to do.
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
MP 830 flashes between the copy button and hazard light(triangle symbol with squiggle in it)12 x.then starts the same 12x after a short pause.It will not do anything..whats the problem?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My ink cartridge on my canon MP 390 will not move to the middle so I can remove the ink tank.
Russel, try the following, open the casing so that you can view the round bar on wich the cartridge mounting is attached, then use kleenex or towel paper to remove any grime on the roundbar on that unit. then apply vaseline or 3 in 1 oil onto the whole length of the roundbar. Lastly with your finger try and move the cartridge unit gently without any force. If it still doesn't move then you should see that either the belt or belt drive tension is correct and moving freely, if it does, then place your finger under the cartridge unit and lift it gently upwards, while lifted try move it to the other side of the printer. If not get back to me.
May 10, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Canon multipass mp 390 manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=9722
Apr 02, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Repair manual for a canon mp 390 printer
Change the cartridge message. I changed both black & color but still the same message would appear. I can NOT make any maintenance ( cleaning the nozzle,....)
Mar 04, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon mp 390
The carriage the cartridges have probably been jammed into place during the move. I would suggest a trip to the local repair shop; however, you can try to manually free the carriage. Be warned consumer printers have a lot of plastic in them and you run the risk of doing more damage this way.
Mar 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
