Question about Epson LX-300 Matrix Printer
EPSON FX 2175 always printing JL 1284.4 @GJL
I reformat my computer and install the driver of epson fx2175 after installation the printer print this "JL 1284.5 @GJL" message and also in the test print.
when you print your documents in windows base programs the printer work but not in dos base programs using by our finance dapartment. some words are mis spelled or wrong letters.
how can i fix this problem, pls. help me to resolve this...
thanks
chris
  • Anonymous Feb 11, 2009
    We are preparing our payroll through an application software supplied by NIC. The reports are set on 15" x 12 " in DOS mode. But the printer prints the report on the basis of 11" height. And our single reports have around 25-30 pages. So how we can get the correct print
  • diliptayade Mar 27, 2009
    i have no drives of epson fx2175
Sometimes the printer head is locking/stopping at the right side
Posted on Feb 05, 2009
  • dsaint720 Feb 05, 2009
    what could be the reason. After printing some documents and it just stop at the right side of the printer
In my computer not install the driver of epson fx2175 i have not driver
Posted on Mar 27, 2009
    send drive of epson fx2175
Epson fx 2175 setting custom size
Maybe you reinstall the drivers, and make a cold reset. sometimes nead too clean fierst, the move control slave of carhead....
Jan 24, 2014 | TallyGenicom Office Equipment & Supplies
Just instaled my epson fx-2175 While giving test print it shows "document failed to print" i am using usb cable. pls help me.
when you print, there is come on/ say "document has been sent". is that right ?edy_bubat_6.jpg
so the problem is the connection, usually this problem in the number USB port on setting properties with the number USB port on lap top that you have plug in.
May 29, 2011 | Epson FX 2170 Matrix Printer
How to check epson fx-2175 Head
how to download epson fx 2175 printer cd
Oct 04, 2010 | Epson FX 2170 Matrix Printer
I just have installed Epson FX 2175 printer but it is not printin
reinstall the printer driver, if the problem persist try changing the parallel cable.
Sep 23, 2009 | Epson FX 2170 Matrix Printer
Printer epson FX-2175 cannot print
1. self-test ( press & hold the paper feed button while turning the printer on)
-conversion cables may or may not work properly-
2a. if cable is parallel, open command prompt and type DIR > LPT1
2b. if cable is null-modem, open command prompt and type DIR > COM1
2c. if on USB, open printer properties window and do a windows test page
if 2c fails, re-install driver
Else, it's your application.
Apr 06, 2009 | Epson FX 2170 Matrix Printer
FX 2175 printer
use the lpt (parallell port) not the USB. and be sure that your computer have the lpt port. if not, buy a pci one. recommend the use of windows xp. are you sure that your printer is FX 2175 or is FX2170?
Jan 26, 2009 | Epson LX-300+ II Matrix Printer
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
1,016 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
