Question about Hotpoint Dryers
The finish on the inside of dryer drum is peeling
The dryer is a hotpoint heavy duty model 840k and the finish on the inside of the drum is peeling like old paint..just peeling off. The dryer is approx 10 years old..We have never seen anything like this.
Any suggestions?
Thanks
Kay
kaymgal@rogers.com
  • Anonymous Mar 24, 2014
    Cracked and Peeling Paint interior of clothes dryer
  • Hotpoint Master
  • 3,463 Answers
Probably due to the age of the dryer, and continous use, especially if it has been used on high heat settings, also the continuous action of clothes turning and thigs like zips and buttons will contribute to wearing away the enamel.
Posted on Dec 11, 2008
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
GE DSXH436V1WW heavy duty large cloths get caught
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
Feb 24, 2009 | Dryers
Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Dec 30, 2008 | Whirlpool LGR7646E Dryer
I have a Heavy Duty - 5 cycle dryer that is squeeking. We've taken it apart and found that it's not the belt but something towards the back end of the drum. Would there be a gasket of some kind that has...
Could be a dry rear drum bearing, if it has a removable rear panel, unscrew it and spray the end of the drum shaft and bearing with Wd40 or similar.
Please rate this solution
Dec 05, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
696 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
