Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Hi, I have a Samsung HLP 4663W TV and cannot get it to power on. We bought it used about 4 months ago, but has been fine.  Did not notice any problem when we shut it off, after a couple of hours would not turn on, timer light blinks when tried, sometimes lamp lights up and sometime the standby one.  I have it unplugged to try cleaning it first, I was reading how and then lost it, started telling me how to get to the fan to blow the dust out, can you advise, Thanks.
    Genius:
  • 1,199 Answers
Get a high pressure can of air and blow out circut boards with quickshort bursts (after removing lower back pannel! It may also be your flyback voltage regulater (about 60.00 for part!
Posted on Dec 11, 2008
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Installing a color wheel
These are set at the factory so no adjustments should be required. The part will come with the installation instructions.
Dan
Mar 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Lound humming noise and color distortion
you will be able to fix it. the sound you heard was a color wheel.. the part number is bp96-00674a
Mar 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
If you have already replaced the lamp and ballast, to no avail, then it is time to take it in to a certified repair center.  Most will charge a nominal diagnostic fee.  My 61" did the same thing and it turned out to be the Light Engine (of which the DMD Board is a part).
If the problem were the color wheel, the lamp would come on for a bit until the color wheel sync couldn't be achieved and then it would turn off.  The all-3-flashing-lights problem is the lamp.  Here is a page from the service manual on the 3 blinking lights problem.
The Light Engine controls the ballast via a separate signal than the 320 Volts.  The voltage reading means that the Power Board is working properly.
I have a samsung hlp 4663w dlp tv...it just stopped responding to either the remote or direct attempts to turn the picture on...the tuner/amp is working fine as we still have audio, just no video...there...
Bob I have seen the DMD on the light engine cause this
The DMD board is available through your local parts distributor
You said you had sound so the analog board is working
The digital board may also be suspect
It is a lot more expensive than the DMD
I would replace the lamp if it is over two years old just on principle
Good luck
Jan 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv going fine, goes out and the timer and lamp on off switch flash. Turned off and back on and tv worked a few times then get the flashing timer and lamp again. I live in Leadville, co.. a hundred...
its the problem in the circuit board so resolder convergence ic's. if that does not work, change (STK-xxxx). they are located on the main power supply board.
there are two such STK ics on the board replace both of them.
also check for any blowned fuses on the board.
Sep 24, 2008 | Samsung Televison & Video
Samsung hlp 4663w
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Dec 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung hlp 4663w picture is all horizontal lines
Bad color wheel...have it checked by a quaified tech.....
Must have lamp code number to get color wheel #.............T.
Dec 08, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
