Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
My sansa turns on then off
My sansa e250 wont stay on it turns on off on off and keeps doing that i already try formating it but it wont format and almost all my memory is missing
  • 8,596 Answers
Do a firmware upgrade, but it sounds like the hardware is probably faulty. The firmware upgrade is available from Sandisks' website. Unfortunately, if that fails it may be repalcement time.
Here is some addl info:
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How can i fix my sansa e250 2gb PLS HELP
It sounds like you are having some firmware issue..To resolve that problem, there are two things you can do..
First, try to reset the device the device by pressing the power button for about 15 to 20 seconds...
second upgrade the firmware on the device even if you have done so already...
For additional help please contact me..
Please rate accordingly
Thank You
Computerrep
Mar 19, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e250
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 13, 2008 | SanDisk Sansa e250 MP3 Player
Music
Mar 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 "refresh database" error
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 09, 2007 | SanDisk Sansa e250 MP3 Player
The Screen Stays black and the ring turns blue and thats it
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250 MP3 is buggin
Best of Luck.
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
Try Formating the Sansa. 1.My Computer 2.Right click the sansa icon 3. clock Format. Let me know if this solved your problem. D.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 will not play videos
Download latest ver of Quicktime
Jun 23, 2007 | SanDisk Sansa e250 MP3 Player
It wont add songs
Did you already try to format it (go to my computer then right click the device and click format) That should solve the problem
Jun 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
