Question about Onkyo DX-C390 6-Disc CD Changer
CD SKIPS CD'S SKIP CONSTANTLY. SKIPS ON NEW CD'S ALSO. TRIED CD LENS CLEANER AND IT DID NOT WORK. DIRTY CD AND VIBRATION HAS BEEN RULED OUT.
    Scholar:
  • 58 Answers
  OK.  I think I can help.  There are two very simple solutions to a skipping CD player.  You have tried one already, that is, clean the laser-reading eye.  Lets assume you did that correctly and that is not the problem.         So, to continue, the machine must be opened. Equipment required: Jewellers screwdrivers, small number one screwdrivers, cottonswabs or Q-tips, Petroleum jelly, 100% isopropyl alchohol is ok but if you can use Denatured alchohol that is the best.        Using a set of fine jewelers screwdrivers or just a small #1 Regular or Philips screwdriver to remove the top cover of the CD player.  Don't force anything and place the screws in a cup so they are not lost or misplaced. I work in a plastic cafeteria tray to contain any dropped screws    The problem here usually occurs in trusty old CD players that have always worked fine and the problem (skipping) starts out small and gradually progresses to always skipping.  The problem and solution are mechanical in nature.    First locate the laser eye and check it physically for any optical obstructions (dust, dust-bunnies, lint, feathers, hair, lumber, etc.)    When you are sure the laser-eye is clean find two parallel small (usually 1/8" or about 3mm wide by about 3 to 6 inches long ) chrome metal bars that the laser eye rides back and forth on.  The eye assembly has a small contact-lens looking clear plastic lens mounted on a plastic carriage that moves from the center of the disc toward the outside as it tracks the disc.  It will have a small ribbon wire harness that can expand and retract with the travel of the laser-eye carriage.  Now look at the two-parallel shiny metal bars the carriage should slide on. The lubricant on these bars lets the eye assembly move smoothly without vibration (or skips) over the length of the two steel bars and your CD plays perfectly when they are clean and lubricated.  This skipping problem can occur if something sticky is spilled into the unit. Soda or beer dries out and if it gets on these steel bars the laser-eye assembly can vibrate and chatter as it tries to track over the CD's info causing skips.      So the solution involves carefully testing the unit with the lid off to see what is going on inside when the unit plays (or attempts to play) a CD.  If the obstruction to the path of the eye assembly is severe, the tiny drive gears can be damaged, broken, or stripped and the eye will not move smoothly without new parts (Factory Authorized Service Personnel are recommended in that case)   Use the Denatured Alchohol and swabs to completely clean and dry the steel track rods that the laser - eye slide on, take care to clean any built up old grease (manufacturer lubricant) that may build up on the holes on the sides of the Laser-eye assembly where the steel track rods go through it.  After cleaning the rods use a new swab to apply a TINY amount of petrolatum evenly to each rod.  I cannot stress enough how important it is to use as little lubricant as possible ONLY on the rods and NOWHERE ELSE!  It is very easy to get the petrolatum somewhere you don't want it.  Be Careful!  One mistake here could cost you the entire unit!  after application, physically slide the eye assembly over the bars to smooth out the petrolatum lubricant evenly. (in the event the eye-assembly doesn't manually slide, don't force anything and go to the next step). make sure you did not get any petrolatum where you did not want it, if you did clean it with cotton and good old, denatured alcohol and put a CD in and before playing it, advance the tracks from track 1 to the highest numbered track and back several times to smooth the lube more.  Play the CD and replace the lid and screws in the order you removed them.      Good Luck!
Posted on Dec 11, 2008
What causes CD-player to skip while playing disks.
There can be a couple of reasons that the CD player is skipping.
One is that the disk has fingerprints or dirt on it. (Carefully clean it)
Two, the lens of the player is dirty. (Try a CD lens cleaner)
If neither solution works, your CD player has given up the goods and requires replacement.
Hope this helps you out.
-Steve
Apr 22, 2015 | Audio Players & Recorders
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
Technics SC -HD 501 CD jumping and skipping
If this happens on all CDs then most like the drive is bad or lens is dirty You can try cleaning out the heads using a cleaner disc. If you have a way to get to the lens you can try cleaning it manually. But most likely. It's one of the following dirty lens, bad motor, bad speed control.
Nov 16, 2011 | Audio Players & Recorders
My walkman skips and stutters constantly. Its getting worse. The same cd is fine in the car player.
It could be that the lens needs cleaning. Try a CD Lens Cleaner like this. They can be found at most major grocery stores and supermarkets.
Feb 28, 2011 | Sony Walkman D-EJ361 Personal CD Player
I just purchased a Rowe 100B CD jukebox. Most of the CD's skip a little. Does this mean the CD player is going bad, or could there be another problem. I'd hate to replace the CD player if there's a simpler...
Hi,when a CD skips like that, it means that the lens of the player is getting weak,that's when a CD player skips.
You might want to replace the lens of the player or before doing that,you can use a lens cleaner to clean up the lens, might be dirty..
After cleaning the lens and it still skips, you will need to replace the lens.
Would advice, if it's still on guarantee, you could simply go and replace it with another one,instead of going through the stress of repairs. Just an advice.
Have a nice day..
Feb 17, 2011 | Audio Players & Recorders
Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
You need to open the unit and clean the lens with good quality cotton bud / swab with care.
Still no joy, replace optical lens.
Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Jvc kd-g502, cd player skips constantly. has been cleaned could the cache need cleaning and how?? Carol
Common skipping issues can be:
Scratched discs, recorded cd-r's on poor/cheap media, dirty laser lens, disc spin motor binding, laser asm. slide rails needing re-lubed. Of course defective components can cause it as well.
Geno
Mar 05, 2008 | Audio Players & Recorders
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
CDA-9855
Try lens cleaner first, always the best idea. If it makes a clicking sound when trying to read the discs, you're looking at a bad optical pickup.
Oct 24, 2006 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Onkyo DX-C390 6-Disc CD Changer Logo
975 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
