Question about Maytag Washing Machines
Trouble code F DL - Maytag Washing Machines
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Washer trouble
F DL is a code for door lock failure. Either the door latch is bad or the main control is not sensing the door latching and is giving the code. Many times it is a bad connection where the door latch wires connect to the main board.
Post back with any questions.
Thanks/mike
Jan 12, 2008 | Washing Machines
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
My music creator 4 wont let me register my product
HI ^^
take this latest version
download the full version of Cakewalk Music Creator 5
Release Name: CAKEWALK.MUSIC.CREATOR.V5-ADDICTION
Download:
http://hotfile.com/dl/7508024/76ecddc/cmcv5.part1.rar.html
http://hotfile.com/dl/7508027/7bd05b2/cmcv5.part2.rar.html
http://hotfile.com/dl/7508026/7b1d1bb/cmcv5.part3.rar.html
http://hotfile.com/dl/7508028/4f36d59/cmcv5.part4.rar.html
Any troubles just let me know
plz rate it FIXYA ;)
Jun 26, 2009 | Cakewalk Music Creator 4
HP dvd640e not recognizing DVD+R DL
6/25/9:  While this external HP DVD640e burner was listed as a NEW drive - "new" meant never used. A check with HP techs told me the unit was a 2005 factory closeout and the dual layer disc required for it is a 2.4 speed disc. I bought a 2.4 speed DL disc and it works perfect in it.  As far as seeing a CD when a DVD was installed is presumed also the fault of having the wrong speed disc in it (that lot of Memorex DL discs I am also having trouble with elsewhere too). Double-checking my profiler, it does give speed as 2.4x as the burner's profile. Alas, the problem was my newness to the DVD technology. A slap to the forehead and move on.
Jun 19, 2009 | HP dvd640e DVD±RW Dual Layer Burner
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Trouble code
F/dl= Door Lock Error
A DoorL ockE rroro ccursif t hed oorc annobt el ockedl.t willt rvt o locki t 6 times
befored isplayinthge e rror.
PotentialCauses
. DoorL ockM echanisbmr okeno r removefdr omt heD oor
. CheckD oorL ock/SwitcAhs sembly
. Checkth ew ireh arnescso nnectiontost heD oorL ock/SwitcAhs semblayn d
CentraCl ontroUl nit( CCU)
. DoorL ocl</SwitAcshs emblFv ailure
F11= Serial Communication Error
Communication between the CentraCl ontroUl nit( CCU)a ndt he MotorC ontroUl nit
(MCU) cannot be sent correctly.
PotentialCauses
. CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
Unit (CCU)
. Checkt he Drives ysteml or anyw orno r failedc omponents
. ReplaceM CU
. ReplaceC CU
. Replace Motor
. ReplaceW ireH arness
Feb 22, 2008 | Kenmore 42822 Front Load Washer
Washer trouble
That is a door lock failure code..which means either the door latch assy or in the worst cast the main computer (ccu) has failed. Make sure the strike on the door is not broken and try the latch first.
MMP8500 driver install and music DL
http://www.mediafire.com/?sharekey=96250eeecc0a116b0f83d91f6dff7c38e04e75f6e8ebb871
ALL FILES.zip contains every file on my copy of the installation disk.
Jul 07, 2007 | Memorex MMP8500 MP3 Player
Washing Machines Logo
180 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
