Question about Whirlpool GEW9200L Electric Dryer
Whirlpool Dryer Model#GEQ9800LW0 will not get hot
Dryer will Not Get Hot
OUr dryer will spin but will not get hot
Sounds like a heating element. Those can run pretty cheap and are not hard to replace.
Suzanne
Posted on Dec 11, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If I may add with the indulgence of trystakarm, other components that may and can cause this fault could be:
  • thermal fuse, once off would have to be replaced;
  • thermal cutoff, automatically resets itself when temp goes down;
  • relay, that actually does the switching on/off of the heater element;
  • logic controller board, that controls the relay based on triggers from other sensors.
Good luck and Thank you for using FixYa. Happy Holidays.
How di i get access to the heater element on the Whirlpool model GEQ9800LW0
at the top of the lower small panel, use a putty knife to slide between the clips holding panel and pull panel out, bottom of panel has tabs holding to cabinet, you will see long heater box, element slides out
Sep 03, 2010 | Whirlpool GEW9200L Electric Dryer
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Whirlpool elec dryer, very loud and stops spinning.
The belt is probably bad and the noise is most likely the guide wheel for the drum
Jun 11, 2017 | Whirlpool Dryers
I have a Whirlpool dryer model LGN2000PWO. It
you have an air flow problem. plugged lint screen, dryer vent partially or totally plugged with lint. dryer sheet stuck to the back wall iside the dryer. outside vent cap plugged or not opening. collapsed dryer vent or vent with too sharp of bends in it. and worse case scenario the dryer blower wheel too full of lint. this is provided the thermostats that the tech put in were of the correct heat range and limit.
Oct 17, 2009 | Whirlpool Dryers
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
How do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Apr 10, 2009 | Whirlpool GEQ9800L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
554 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
