Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma mp150 saying paper jam but cant see one
My printer keeps saying there is a paper jam, i have looked in all parts i can see but i cannot find any paper jam. I have read other peoples problems and one says to make sure the sensor is clear from dust/paper but i cannot see a sensor, can anyone tell me where to find this or if there might be any other solutions Thanks keeps saying the paper is jammed, and it isnt, and wont **** up the paper.
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Dec 11, 2008
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My printer keeps showing E and saying paper jam but it is not any paper in there
power down. recheck all printer heads are clean, no small bits of paper jammed?
power on
run self clean test if allows the funcionality.
Oct 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error E-3.jammed paper and there is no paper jam canon Pixma MP150
The printer needs to be opened and greased. It happened to me too.
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Canon PIXMA Mp150 paper jam, how can I get the cover off to remove the jam?
open printer scaner liake as change printer cartridge open jum paper
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
353 people viewed this question
old marine
old marine
