Question about Car Audio & Video
Injectors not firing- car wont start
Wired in sony stereo/cd player in as per instructions provided by shop that sold me the unit . instructions were wrong . they mixed up the constant feed and the ign feeds .
Now i have NO constant power feed anywhere . and injectors wont fire. have checked fuel pump and plugs and both working fine.
Feel its blown a fuse somewhere but i cant find where .
any ideas on where to look ?
have checked all std under dsah fuses and the 2 under hood boxes
  • 2,427 Answers
The injection fuse is located in under the hood, There is a main fuse box there it some where close to the battery or air filter. The fuse is labeled injection or fuel. You might what to have a diagnostic done to determine if you damaged the cars ECU (on board computer) chances are you damaged this from short circuiting it, this controlls the fireing of the injectors as well so if its damaged you will have the same problem as well as many many many others. If it is damaged you will have no choice but to replace it.
Posted on Dec 11, 2008
Diagram abot wire harness
A wiring harness for the unit is most likely more than you would pay for a used unit at a pawn shop. Most sony receivers have the terminals labeled on the circuit board. If you are lucky, you can find a dead one at a stereo shop or repair shop near you. They didn't name them explode for nothing. Be careful. 25312832-wng3opgl1pug32fsc4t4fc4i-2-0.jpg
Dec 08, 2014 | Sony XPLOD CDX-GT200 CD Player
Cdp c221
This was sold as part of a stereo system. The CD part of the instruction booklet starts at this web page (page 15 of the manual)
Jul 31, 2014 | Sony Audio Players & Recorders
Changed Radio and now car won't start
What stereo did you use as a replacement? If you used a aftermarket (kenwood, sony, etc) cd player, you need to use the proper adapter harness. These cars have a build in theft deterrent system that involves the stereo. So, when you replace the stereo, a component of your anti theft system is missing. The use of the harness gets around this feature somehow, and allows you to use aftermarket CD players. Also, ensure that no wires are getting pinched behind the stereo, and that all your connections are soldered and shrink wrapped to avoid any future problems. I have provided a link for the correct adapter harness to your vehicle.
May 03, 2011 | 1999 Oldsmobile Alero
Player will not come back on after about 1 year of good service, only shows a speaker with an x across it, wont come on , take a cd or anything.
You have a shorted speaker wire and the unit is protecting itself from damage. Fastest way to confirm is to disconnect the speakers at the unit. If it powers back up, add 1 speaker at a time back on. it will cut back out when you find the bad wire or shorted speaker. If you still have an issue, post a comment and I can help you further.
Sep 30, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony CDX GT200 does not work... is there a fuse in this radio? I cannot turn on the unit now. I just got my car back from the repair shop and they replaced my battery and alternator, but now my radio...
There is a fuse in the back of the stereo unit. Also trace the red wire from the stereo to where it's connected, and check the fuse for the circuit that the stereo is connected to.
May 22, 2010 | Sony XPLOD CDX-GT200 CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
My sony cd player will turn on but wont play sound?
reset the unit. (use the reset button if it has one or remove all power to it) check the power to any amps you have hooked up and check for short circuited speaker wires (the - wire touching the + wire) all these things will cause you to have no sound.. if that dont work have the unit looked at at a audio shop it might need replaced
Aug 03, 2009 | Sony CDX-L410X CD Player
Code for Sony Car Stereo CDXm610
You can find code on manufacture site! Just follow instruction and you need serial number that you got with yours CD player.
good luck
Jun 16, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Kenwood KDC-X890 won't turn on
maybe a fuse blew out or maybe a wire came loose. check the fuses first then check the wiring make sure everything is cool. then smell the cd player if it has a funky burnt smell kind of like burnt olives or almonds it blew the diode and its toast.
Dec 08, 2007 | Kenwood KDC-X890 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
