Question about Global Product Resources Deco Breeze Byzantine floor fan Table Fan
I just purchased a deco breeze floor fan and put it together. The male plug from the motor and the female end do not appear to match - -female has three small holes much closer together than the male plug -- I am a female myself age 62 - don't know much about these things but it doesn't look to me like it will work (fan was ordered online thru Amazon) Is there a converter plug or something?
  • cassiespeaks Dec 15, 2008
    Deco Breeze is sending a new fan - cord cannot be replaced by consumer. Thanks for a quick reply.
    Genius:
  • 1,199 Answers
They sent you the wrong plug...Must have been packed wrong! get in touch with the vendor and they will get you another cord!...Better yet call the company who makes the fan and they should have the right plug out to you in no time!...this kind of thing is very commen.have a good day
Posted on Dec 11, 2008
How to replace breakline 1998 Nissan frontier
You have two choices, either replace the whole line, or just cut the bad part out with a tubing cutter, then purchase a pre-made line the same size & length that you cut out, you can take the old line to the auto store & match it. While your there, you also need to couplers, which are female on both ends and 2 male connectors that will fit into the couplers you just bought.. Now you'll also need a double flaring tool (cheap at Harbor Freight).The brake line that's still on the car, you want to dry & either emery cloth or steel wool the ends where you made the cuts. Now slide 1 male connector on each side, then double flare each end of the tubing. once that's done you can put your new female couplers on each end, then connect the new length of tubing you just purchased to both couplers , the new tubing already has new male connectors , and is already flared for you. Not a hard job if you have the flaring tool. good luck. Don't forget to bleed the system when done.
Sep 20, 2014 | 1998 Nissan Frontier
The hose connection nipple is smaller than the garden hose-connector and leakes. Do I need a special hose or will putting plumbers tape on the nipple stop the leak?
No, that would probably leak too. What you need to do, is go to your local hardware store or home center (Plumbing Dept) and purchase a female to male connector. The female end is to connect to the unit's male hose connection and the other (Male) end, needs to be the same size for garden hose connection. Make sure that you use an appropriately sized washer for the Female end.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Danby DDR5009REE Dehumidifier
There is a green wire with a 2 prong female end in the center back of the cook top. where does this attach I have looked and felt everywhere. I spoke to tech support he said it was the grease pan ground....
Angeashmore: We had the same green wire problem. The catch is that the 2-prong female plug just looks like it should receive a matching 2-prong male plug. In fact, at the center back of the pull out Drip Tray there is a very small flange next to a small hole. That flange slips right into the plug, but under those two prongs which then hold it in place. Its length allows you to disconnect when you remove the Tray for cleaning, but if that's the first time you spot it loose, you'll think it plugs in somewhere up front and will look in vain for a matching 2-prong male plug. I'm guessing they provided a ground for the Drip Tray since it is otherwise fully suspended on nylon rollers. No instructions about this in the set-up manual, so likely omitted frequently. It's just a ground wire, and won't really fix anything else, and would appear to work just fine without it, but just a safety feaqture. Confirmed by tech support at Viking on 1/24/2011. Your initial post put me on the path to success here, so thanks! .....Jim
Nov 29, 2010 | Viking 48" 6 Burner, Griddle Professional...
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
I am connecting my dazzle to my pc and to the back of the x box but i try to use windows movie maker to record footage but i cant seem to find the dazzle capture card anywhere on the pc even though i have...
Welcome to Fixya,
What is the model of your dazzle device? Is taht DVC 100? if ever please check this procedure.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task. step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Aug 12, 2010 | Pinnacle Dazzle DVD Recorder
No Picture
Hi And Welcome to Fixyah,
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
How do i connect dazzle to tv to record ps3 gameplay
Welcome to Fixyah.
If you follow any of the videos, it won’t work!
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Regards,
Mar 20, 2010 | Pinnacle Dazzle DVD Recorder
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
I purchased the Porter Cable 20 piece accessory kit part A00438, and no idea on how to assemble this. No instructions included either. This is the kit that allows to put airpressure in your car, bikes,...
First get some teflon thread tape, for applying 2 or 3 tightly wrapped turns around the male threaded quick-disconnect adapters, threaded end on your air hose and compressor before installation.
Note: remember that the female quick-disconnect adapter is also a check valve that will only release air when a male quick-disconnect adapter is inserted, i.e. do not install a  male quick-disconnect adapter directly to an air compressor outlet.
Note 2:Always remember to wear approved eye protection when operating air tools.
Start by installing the female quick-disconnect adapters on a male threaded end of the air hose and on to the outlet port on the air compressor tighten the connections with two open end wrench's. Then install the male quick-disconnect adapters to the other end of the hose, blow-gun tool, and the air chuck tool, (tighten as described above). The other implements in the kit (wire brush attachment, inflation needle, etc...) can be threaded in to the outlet port of the blow-gun as needed.
The operation of connecting  quick-disconnects are as follows: Grasp the tool in one hand, and with the other hand grasp the air line near the end leaving the thumb and fore finger free to operate the spring loaded outer release cylinder on the female quick-disconnect by pulling back on it. With the cylinder pulled back, insert the male quick-disconnect adapter in to the female quick-disconnect adapter, then release the thumb and fore finger from the outter release cylinder, thus locking the two together. check to be sure the lock has engaged by lightly pulling at the tool. Reversing this process will disengage the tool from the air line.
Hope this helps Good luck
Feb 21, 2009 | Porter Cable C2002 Wk Oil Free Umc Pancake...
Global Product Resources Deco Breeze Byzantine floor fan Table Fan Logo
77 people viewed this question
Top Global Dryers Experts
Are you a Global Dryer Expert? Answer questions, earn points and help others
