Back to:
Tags:
Ozaki DT-500 3-Piece Speaker System w/Subwoofer&Wired Remote  Computer Speakers
If my computer doesn't have a sound card, can I... (by 14 users)
By Grant - usenet poster
If my computer doesn't have a sound card, can I still hook speakers up to it and hear anything?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by jeanette_car, posted on Sep 06, 2008
I cant hear sound from my pc and it tells me there is no sound device install but i used to be able to hear it can anyone help me?
thanks
Comment by TERRYBCOOL, posted on Aug 20, 2008
I HAVE A SOUND CARD THAT WAS WORKING . I WAS 2 WEEKS AWAY AND CAME BACK AND MY COMPUTER READS NO DEVICE OR NO SOUND CARD. I CHANGED THE SOUND TO A DIFFERENT SLOT AND EVEN CHANGED SOUND CARDS FOR THE SAME MAKE FOR MY COMPUTER . WHICH IS A COMPAQ. ALSO BEEN THROUGH ADD NEW HARDWARE IN THE CONTROL PANEL. AND NOTHING.
I NEED HELP CAN YOU FIGURE OUT THIS ONE OUTSIDE OF ME GETTING ANOTHER COMPUTER OR MOTHER BOARD ?
THANKS TERRANCE E MAIL IS TERRYBCOOL2004@YAHOO.COM
Comment by moez1234, posted on Jul 10, 2008
no sound i haven't the drivers for a sound card for pc dell dimension 3100
Comment by Guest, posted on Jul 05, 2008
no sound card
Comment by Guest, posted on Jun 03, 2008
ive got acer speakes but no sound
Best Solution
posted on Aug 25, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes.....Most motherboards come with onboard sound....just hook up your speakers to the appropriate jack (usually lime green in colour).
All sound will be heard ....including system sounds.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on If my computer doesn't have a sound card, can I still hook speakers up to it and hear anything?:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2005
Helpful (85)
jessie25
Rating: 0%, 0 votes
How and where would you hook up speakers with no sound card? The short answer is no, but if you hooked up speakers to the LINE OUT on your CD ROM, you would probably hear music that the cd rom is playing, but you would not hear typical sounds that a computer makes.
Thank You!
Solution #3
posted on Aug 28, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I hooked up new speakers to my computer because the old ones suddenly stopped working. Now that I am trying to install the new ones the control panal says there is not audio device to detect.
Thank You!
Solution #4
posted on Jul 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
multimedio audio controller
Thank You!
Solution #5
posted on Jun 22, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
my t5400 surround sound speakers worked fina at first without buying a sound card. I just plugged it into the back. Problem is vista overwrote the speaker settings on an update and now it only shows two speaker setup. No options to reinstall surround sound but i am still looking.
Thank You!
Solution #6
posted on Jun 09, 2007
Not Rated (0)
bluenadas
Rank:Guru Guru
Rating: 85%, 219 votes
Some motherboards come with built in sound cards. Check the outputs on the rear of the computer and see if there are any jacks for audio output.
Thank You!
Can you Help with these Computer Speakers problems?
Computer Speakers
speakers turn on but can't get sound from videos played
Computer Speakers
d865gbf
Computer Speakers
what disk would that be i had the computer for a while
Computer Speakers
system windows xp, i get no sound from these logitech...
Computer Speakers
In my creative 5.1 SA500 i do not hear anything from the...
13 Other Users Have The Same Problem - Continued
Comment by ladycasper, posted on May 28, 2008
no audio device found
Comment by Guest, posted on May 03, 2008
have speakers,but do not know where to plug in?
Comment by johnnydollar, posted on Apr 29, 2008
i hook speaker to my computer
and no sound
Comment by Guest, posted on Apr 23, 2008
i dont have soundcard installed in my laptop.
Comment by Guest, posted on Mar 31, 2008
INSTALLED MULTIMEDIA SPEAKERS DID NOT PRODUCE ANY SOUND
Comment by currygoat, posted on Mar 24, 2008
I have speaker plug in but no sound
Comment by Guest, posted on Nov 17, 2007
sound
Comment by Guest, posted on Nov 01, 2007
harmon/ kardon
Loading problems.
Repair Service
Find Computer Speaker Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
