Question about Whirlpool Duet GHW9150P Front Load Washer
Error message What does the error F-01 mean on my whirlpool duet front loader?
  • Anonymous Dec 15, 2008
    get a f 01 message on the display after i press start
F DL ERROR MESSAGE
Posted on Dec 11, 2008
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Get the code F-01 on the whirlpool duet front loading washer, not sure what this code means
Click this link directly:--- http://mymoremoney.blogspot.com/2011/01/whirlpool-duet-ghw9150p-front-load.html --------------- In this there is instructions and procedure mentioned to resolve the issue. If any part checked out faulty then you can get it from www.repairclinic.com .----------- Thanks.Helpmech.
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have Whirlpool Duet Front loader and am getting a message F20. What does this mean?
That's a new shortcut on a latest keyboard. bring it & attach to the washer.
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Nov 11, 2009 | Whirlpool Washing Machines
Old duet washer -error message F - 01 flashing
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 or you could check E-Bay.
Feb 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal De
