Question about Sony KP-61HS10 61" Rear Projection Television
TV wont turn on
I have a Sony KP-61HS10. I recently moved and made sure not to jostle the tv too much. when i plugged it in the scren was just black with static. then suddenly there was a popping noise (like a fuse blew) the screen flashed red then turned off. i check to see if the fuse was blown and it was not. i then noticed that there was a small amount of black liquid that seeped from somewhere and got on the curcuit board (i have no idea were the luiquid came from) i tried drying the curuit board but still have no picture and tv will not tun on. all i get is a flashing red light on the front panel for the power. when i press it it does nothing. please help!
  • Nick Dhuyvetter
    Nick Dhuyvetter Dec 12, 2008
    zener, thank you for the answer. of course i was hoping it would be an easier solution. i will make sure i get a pro to look at it and give me a quote for the price. and again, thank you.
  • Anonymous Dec 16, 2008
    tv won't turn on
    Problem Solver:
  • 7 Answers
Hi there, well my friend, this rear projector tv has 3 lenses, one that projects red light, one green light and one blue light. the liquid came from those lenses and it helps the light go tru the space. each one has a sensor and if theres not fluid the tv will protect itself and wont turn on.
i'm not to sure if the fluid made any short circuit between components, because is an oily solution and don't have many conductor properties. (correct me if im wrong) but i suggest if you don't have electronic knowledge or skills, don't attempt to repair it yourself, its hard even for experts to remove all the connectors and will take several time to do it.
Posted on Dec 11, 2008
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
TV wont turn on
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Apr 06, 2017 | RCA Scenium HD65W20 65" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Kp-61HS10
protective shutdown, being as sometimes you have audio leads me to believe its vertical deflection. Does the Led flash when it shuts down?
Mar 12, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
