Question about GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser
GE Monogram ZIR36N LH
Door hinge not allowing door to close .. how to fix hinge
22yooper
  • 828 Answers
SOURCE: self closing door hinges
This is not a refrigerator problem BUT, you must insert a tool like a drift punch into one of the holes on the top of the hinge and rotate it away from the door position then reposition the holding pin to prevent it from recoiling.
Posted on Jun 28, 2008
Krames
  • 18 Answers
SOURCE: Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Posted on Nov 14, 2008
  • 1214 Answers
SOURCE: GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Posted on Jan 24, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
adnanbhatti
  • 1188 Answers
SOURCE: GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Posted on Aug 27, 2009
Refrigerator door
If there is nothing blocking the door from closing than more than likely the cam riser on the hinge has broken and causing the door to not line up properly. Look at the hinge on the other door and compare to see if there is a plastic piece that is missing or if there is a difference is looks.
Sep 05, 2012 | GE Monogram Side by Side Refrigerator
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
Have 36 in monogram refridgerator.....after moving units to new location,door is out of plumb and will not close properly
You will need to adjust both door at the same time. You will need a 5/16 wrench. Loosen the hinge screws on the top. Try to line one door with the center post between the doors. Open it and see if it closes by it's self. If so, go to the other door. line it up with the other door, allowing about 1/2" between them. Now see if it will close by it's self. If not, you will have to play with it. The only other adjustment is on the bottom. You will need a3/8" wrench (some have 1/2" screws). loosen screws on one side, have someone pull door up until the top is even with the top if unit. Tighten and then do the same with the other side.Once you have this done, adjust the top hinges. Good luck.
Oct 17, 2009 | GE GSH25JFR Side by Side Refrigerator
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Range Door won't go back on
We found the answer in the installation manual not the owners manual. GE was not helpful.
Step on the latch while holding the door straight up (as if it were closed on the oven). Apply pressure with your foot to the latch and it will open fully. Put the lock in place towards to door. It was then easy to reinstall the door. The installation manual stated that the doors sometimes did this...
Frustrating that the installers are allowed to know this but the owners are supposed to remain in the dark -- unless they are clever like -- ah - ha - ME!
Service call averted!
Jan 02, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
Is a hinge switch possible
Most door swings are reversable and very easy to do. The owners manual should show if it's possible and how to do it.
Jan 30, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
