Question about Sony PlayStation Portable (PSP) Console
PSP unit will not read UMD's. All other functionality is working. Is there any way to clean or re-align the laser?
Sounda Intresting I Will Try This Thanks For The Help. Have A Great Day
Posted on Mar 27, 2007
Found one. www.consolezombie.com has a detailed description about how to replace the umd laser assembly. Just click on the part like your going to buy it and a tutorial will come up. Haven't found out how to align the laser yet.
Posted on Mar 04, 2007
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/benjamin_494963e790f97efb
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
PSP disk drive
your laser is either broken or unaligned. you have 2 options:
1. send it back to sony
2. or try and clean the laser track, remember the gear under the track also needs cleaning.
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Hi Glenpark, Eithr the UMD or UMD laser is dirty.  If it will play other UMD's the UMD is dirty.  I think Gamestop has a device that helps broken and dirty UMD's.  If it will not play any UMD, then you have a problem with your UMD laser.  You can try to clean your laser lens.  Use a Q-tip.  Dampen, not soak,  a Q-tip with a window cleaner. NOT Alcohol. Swab the lens thoroughly with the cleaner, then use the dry Q-tip to dry and polish the laser. Try hard to not leave any lint.
If you UMD still does not function, you need to send it back to SONY. Contact them at 1-800-345-7669.  If you cant get them to fix it Contact The Playstation Clnic at Repairtech@Playstationclinic.com
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
