Question about Adobe Photoshop® Elements 5.0 Full Version for PC
Pictures vertical to horizontal
I have a small problem and I don't know if it's fixable. I have the Photoshop elements 5.0 and I was wondering if it was at all possibl to change a picture that was taken vertically to horizontal.(and vise versa) I don't even know if this is possible to do in general any help would be great!
    Problem Solver:
  • 15 Answers
I'm sure that this is possible. You should select the whole image, and then rotate it 90 degrees.
Posted on Dec 11, 2008
  • waiwai933 Dec 11, 2008
     Hi! If this solution fixed your problem, please click the "Fixya" rating. If it didn't, please click the appropriate rating. This helps me improve my assistance and the time that I can spend here helping people just like you. :D
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
Where can I buy Photoshop 8 for my leopard operating system? Is there an upgrade available? Is Adobe Photoshop CS 8.0 the best version available? What is Adobe Photoshop Element 8?
Hi.
Re:Where can I buy Photoshop 8 for my leopard operating system?
The latest version is Adobe photoshop CS 5 for Leopard.
Purchase available using the link below:
Get Photoshop now at the Adobe Store.
Offers are available from third parties: Adobe Photoshop CS5 - Mac - DVD-ROM - Universal English
If you want the Upgrade Version: Upgrade from US $199.00
Software upgrades available here:Adobe - Photoshop : For Macintosh
No,
Photoshop element is a small version of Photoshop. Interface is oriented to non professional user. Element has only main features of Photoshop.
Adobe Photoshop On Mac OS X 10.5
Aug 14, 2010 | Adobe PhotoShop CS 8.0
10 yr old Quasar 25in color tv. Audio is ok. No raster for picture, just horizontal electron beam trace across screen. No vertical deflection for picture display. Any suggestions other than using tv for...
Don't have specific knowledge about this model but the problem is in your vetical o/p section an is fixable.
In general read below.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 22, 2009 | Quasar SP-2722 27" TV
DISPLAY BUTTOM FLASHED 5 TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL#...
Hi
Thanks for using FixYa. You need to check the horizontal and vertical output wave form at the high side of the deflection which should be a normal horizontal/vertical pulse respectively. Now check the HV output transistor on all three elements and also check the regulator transistor which might have short. Replace the parts/diodes which are gone bad and can be easily replaced. You can order these from the following link --
Projection TV spares parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | Televison & Video
Printing from Elements 6 w/ HP 8250, image pushed to left.
I wish I did have a solution. Photoshop Elements 7 exhibits the same problem. They obviously broke something. I have to use an old version of Photoshop Elements 4 just to print properly. I am a tech support professional, uninstalled all HP software, re-installed latest drivers and problem persists. Sucks.
May 14, 2009 | HP - HP Photosmart 8250 printer
No more picture
Usually this is a problem in teh vertical circuit and generally results in a thin horizontal line through the center of the screen. If that is the case, look for a small flat IC that may be marked LA7837 or someting similar with about 11 pins. This should be the vertical IC. Try resoldering the pins on the IC first. If that fails to resolve the problem, replace the IC. Please note that defective capacitors in the vertical circuit can cause this as well. The more probable defect is the IC. Update this with your results. Also be aware that there are potentially dangerous high voltages inside the set even when unplugged.
Dan
Dec 17, 2008 | Televison & Video
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Adobe Photoshop® Elements 5.0 Full Version for PC Logo
67 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
