Question about Dryers
Gas dryer wont heat
Sets and turns on but never heats
elite kenmore gas dryer smartheat quietpak9
mod 110.95871400
  • dpdpres Jan 26, 2009
    I never here the gas turn on and dryer does not heat up
  • Anonymous Mar 26, 2014
    i hold down the reset/unlock button for 3 seconds and it wont unlock Kenmore SmartHeat QuietPak9
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Posted on Dec 11, 2008
He3 gas dryer not heating
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
My Kenmore Elite Smartheat QuietPak9 dryer quite blowing hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 06, 2011 | Kenmore Dryers
Hi I have a Kenmore elite smartheat quietpak 9 HE4. It is no longer heating. What happened?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Dryers
My kenmore elite Smartheat quietpak9 model HE4, keep turn off after 15 to 20 minutes, it does getting hot. Could you please let me know what will be a problem. I bought it used so I am not sure how old is...
might need a clean out keeping heat inside of dryer,or you have abad motor,take the vent line off the back of dryer and run it to see if the block is in the vent line or in the dryer,also take off bottom panel,unplug dryer,take out lint filter and then remove the duct that the filter slides into,if it's blocked clean it out and you should be all set,usually the thermal fuse pops when this happens so that's why i say you could have a bad motor
Dec 15, 2009 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smartheat quitpak electric dyer
Hello talee725. the dryer has heat sensors located throughout. One at the air intake & exchaust of the heating element including the air exchaust of the drum. Disconnect the AC power, close the gas valve is gas powered, clean them and check the sensors with a DVM in the ohm scale for open ckt. They are usely round in shape with 2 wires connected. If test open call a local appliance parts/repair center for price and stock.
Nov 05, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 - Smartheat Quietpak9
Dryer heats but will not dry clothes. Uncloged linted in screen and where the tube is. Did not fix the promblem. Could it be the heating element? And if so what is the cost to replace it?
Nov 15, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
286 people viewed this question
Top Dryers Experts
