Question about Kitchen Ranges
Please be my hero
I would LOVE it if you could tell me what the whirlpool gold slide in range error EO F2 means. I am hoping I didnt permanently fry my touch pad. I pot of water boiled over into the front of the stove. Enough to drip out of the bottom. Is there anyway to clear this out so I can use the keypad again? If not, any idea how much it is going to cost for me to get a repair person out to replace it? I love my stove but I think I killed it. Well, maimed it severely. Thank you for your help!
  • magick0468 Apr 17, 2009
    MODEL# GY396LXPT00
    EO-F2 shorted keypad.
    I have a company coming out sent from Whirlpool on Monday... other than $69 trip fee cant give me any estimate info. Per Fridgetech the keypad is shorted and needs replacement -- now that I have the model # I was hoping someone can enlighten me on what a fair charge should run on this repair. If its going to be $500 I will purchase a new range for $750 and not have the controls below the cooking surface (poor design).
  • 473 Answers
E0-F2 means a shorted keypad and will need to be replaced. Not sure how much the repair would cost w/o knowing the model # of the oven. This repair can range from $250 - $500 depending on the price of the part. Sorry for the bad news.
Posted on Dec 12, 2008
My whirlpool gold accubake displays an eo f2 light, what does that mean?
Disconnecting the power to an appliance resets the control module.
Feb 17, 2015 | Whirlpool Kitchen Ranges
What is the eo f2 error code mean on a whirlpool oven
E0 F2 is a stuck key on the keypad. If your keypad is not available from the factory you may find a replacement unit here: http://www.fixyourboard.com/ledgestone.html
Aug 17, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Error message on Whirlpool Gold gastop range: E0 -F2-
It means "shorted keypad".
1. Disconnect power from oven for longer than 30 seconds.
2. Re-apply power and observe for longer than 5 minutes.
3. If failure remains, disconnect power, replace control, then
go back to step 2.
4. Unplug and replug membrane connector.
Dec 29, 2007 | Whirlpool SB160PEE Gas Single Oven
Error Message: EO -F2-, but I don't have a manual
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Mar 04, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Kitchen Ranges Logo
245 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
