Question about Microsoft Xbox Console
Xbox dvd drive
My dvd drive wont stay closed on one system and will not open on my other system. what can i do to self fix?
  • 11 Answers
I have had both these problems before.
For the drive tray door that will NOT open do this.
  1. Turn off, disconnect from the TV and unplug your XBOX (otherwise your risk the remote chance of causing a short).
  2. Get a paper clip and insert it into the tiny hole just to the left of the power button to manually open the tray door.
  3. While the tray is open take a Q-tip (aka cotton swab) and clean the edges of the tray guides and carefully spray a little compressed air into the bay (***do NOT shake can before or during use and hold the can vertically so only air and no refrigerant comes out***).
  4. If this does not fix your problem you while have to have your XBOX serviced unless your are comfortable taking your XBOX and DVD drive.
For the DVD tray that will not stay closed.
  1. See step 3 and 4 above.
For disassembling your XBOX and DVD drive there are numerous guides online. (www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm)
Posted on Sep 09, 2009
Game stuck in the back of my xbox 360
If you have a xbox 360 the DVD drive is self contained you wil have to open the system to retrieve the game go to www.llama.com to find a tutorial on how to open the system
Feb 14, 2013 | Microsoft Xbox 360 Console
My xbox tray wont open i have xbox open right now opens when it wants to
PROBLEM WITH YOUR XBOX 360 DVD DRIVE.
BUY A NEW ONE. MAKE SURE YOU THE ONE THAT IS COMPATIBLE WITH YOU XBOX
FOR EXAMPLE
XBOX
XBOX 360
XBOX SLIM
JUST GOOGLE XBOX THEN THE MODEL OF YOUR XBOX THEN DVD DRIVE.
BUY IT THEN BUY THE TOOL TO OPEN IT. (THIS IS VERY IMPORTANT)
DISCONNECT THE CABLES THAT WENT TO IT THEN REPLACE IT WITH THE NEW ONE
HERE YOU GO.
HERE IS THE LINK http://cgi.ebay.com/DVD-Replacement-Drive-Xbox-360-BenQ-VAD6038-TOOL-/170550438207?pt=Video_Games_Accessories&hash=item27b599293f
IT COMES WITH TOOLS. EVERYTHING REQUIRED.
CLOSE IT BEFORE TURNING IT ON TO STAY AWAY FORM RED RINGS(OVERHEATING)
PLEASE RATE IF THIS HELPED YOU
Apr 10, 2011 | Microsoft Xbox 360 Console
X box system coming on but not reading disc keep opening and closing tray
This is a issue with the DVD drive of the xbox 360. You can attempt to replace the drive it's self but it is a long process which requires you to spoof the new drive. You can also contact Microsoft to get the drive replaced.
Aug 26, 2010 | Microsoft Xbox 360 Console
The CD tray wont open on my xbox 360
Do not attempt this fix ur self if your not familar with the dvd drive parts . The problem is the band on the dvd drive motor under the disc tray is slipping . To fix this use a rubber band. Step 1 Remove your dvd drive unscrew all 4 screws , 2 remove green board carefully . 3 unscrew any screw under the disc tray and remove this disc tray , step 4 get a rubber band a small rubber band and replace the band thats slipping put your dvd drive back together and ur good to go . If you do NOT want to do this your self you can go to Solomodsdotcom and they will fix the dvd drive for you . Google search to to replace rubber band on 360 dvd drive . You tube has videos on how to but i wouldnt recommend doing it your self if your not familiar with the parts .
Aug 07, 2010 | Microsoft Xbox 360 Console
My xbox360 thing that reads the games wont stay closed
all it is ur lens isnt in the correct starting position however its a little annoying when everytime u what a go of the xbox it takes about 20mins to get it to work but now iv fixed it properly well all i did is open the xbox comnpletly and get 2 dvd drive open it up i was shocked wen i opened up mine there was a dog on the lensand all over the whole grease on the bars were coverd in hairs i pulled the lens to the correct starting position and clean the dvd drive a best as i could amnd now it work perfect
this will fix it because over time this method will take longer and longer trust me 3rd xbox
Mar 19, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 starts up randomly, tray opens and closes spontenaously
I have the same Problem my X box came on spontaniously and the DVD tray opens and closes non stop till I get the RROD code. it will play games and DVDs only if it stays closed long enough to start then it opens up and starts the cycle all over. I opned up the DVD drive and can't see any thing blocking any thing I even used a Q tip to pit a little oil on the screw meckanisim that opens the drive and blue it out with compressed air. and it did not fix the problem I am going to have to buy a new drive my Drive is a Philips drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
Help
This is a known issue with the 360, most likely the cause is that the spindle that holds the disc is loose or completely broken off. As the way the cap for the spindle was made, microsoft used a magnet to hold it in place instead of glue or soldering as most drives would have. This is just another instance of inferior workmanship on their part to save money.
Contact 1-800-4MY-XBOX to get an RMA issued.If your console is out of warranty, open your console and get the model # of the DVD drive used in yours, then check online for any vendors selling replacements.
Jun 30, 2008 | Microsoft Xbox 360 Console
Door wont stay closed
call ms they might fix it if its under a year old
May 03, 2008 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
88 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
