Question about Panasonic DMR-E50 DVD Recorder
My remote doesnt work my dvd recorder it saying 3 check remote
When i press any key on remote dvd recorder gos back to 3 check remote i need to unlock remote cam anyone solution this problem.
    Problem Solver:
  • 5 Answers
THE aswer is in the manual that can be had on line. You have 3 different remote typse, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 for a few seconds and it will change the setting. When getting the error "3 check remote" that said you have it currently on setting 3. Try 1 or 2.
Posted on Jan 21, 2009
I accidentally set my Sony RDR-HX720 remote control setting to DVD 1 while I was reconfiguring various settings on it, and found out to my horror that the damn remote effectively died! - with no way to...
while pressing 'ENTER' on your remote, press and hold down the number '3' key for approx 4 seconds and then it should work.
the same process goes for 'DVD 1' and 'DVD 2' depending on the remote setting on the recorder.
there is no need to point the remote at the recorder when doing the above as it is only the remote itself that is being programmed.
hope this helps.
Jun 11, 2010 | Sony RDR-HX925 (250 GB) DVD Recorder / HDD...
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
LG RH266 DVD/HDD RECORDER The HELLO message keeps repeating when turning the unit on. So cannot receive picture etc Is there a code from the remote to fix this or a part replacement ?
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
Oct 14, 2009 | LG DR787T DVD Recorder
How to unlock code for LG dvd player model DVX183?
Hi, have you tried this? It worked on my LG player.
1. Open DVD tray
2. Press "0000" on the remote.
3. A screen will appear saying NEW REGION CODE displaying the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD tray.
7. Power off
Feb 21, 2009 | LG XBR446 DVD Recorder/VCR
Hi, when i press any key on the dvd recorder remote (panasonic dmr-e55) i comes up with remote dvd 1 everytime and wont do anything else, weve tried umplugging it 2 but that doesnt help, do u have any...
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. DVD 1, DVD 2 or DVD 3. Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel DVD 1. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following, On your remote press the "Enter" button and hold it down. Then press the "1" button at the same time for two seconds, then release both. This will change your remote so it sends signals on DVD 1 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Dec 29, 2008 | Panasonic DMR-E55 DVD Recorder
The controle wont work the player is saying set 1 how do I get it
Easy fix.
Press the "Enter" key and hold it down. Then press the "1" key and hold them both for around 10 seconds. This will reset your remote and it should work ok. In the unlikely event that it doesn't work, repeat the procedure but press the "2" or "3."
Cheers
Dec 17, 2008 | Panasonic DMR-E55 DVD Recorder
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Remote is Stuck in DVD 1 mode
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Panasonic DMR-E50 DVD Recorder Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
