Question about Dryers
My dryer won't turn when on, I took the back off and a belt it broken. I know that part number for the belt. Where can I find step by step instructions to replace the belt?
If you look up the manufacturer, they will give you instructions on how to replace the belt,or yo can download the info via the internet
Posted on Dec 11, 2008
Why won't my dryer turn ?
It sounds like the belt is broken, it is a big belt that turns it around the drum..you can look up your dryer by finding the make and model and serial number on the back someplace, then look up which part number you need, if you dont know how to install a new belt, a handy man may be able to help you for much less than getting manufacture to come out unless its under warranty still, good luck
Sep 08, 2014 | Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer won't start. If you turn the start know to the right, there is a humming noise so it sounds like the motor is getting current, but the dryer drum never starts to turn. Dryer is an electric...
the main belt is broken or has come off,back needs to come of and belt replaced.new belt must be put in warm water to loosen it up ,quite hard to get it back on but can be done and will save you a cal out fee.adrian,,,,,,,,,,
Aug 31, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Elec. dryer
remove the front panel,find the idler arm wheel,the belt goes under the idler wheel and onto the motor pulley,put back together-mike
May 27, 2008 | Kenmore 65924 Electric Dryer
WE HAVE A KITCHENAID MODEL NUMBER YKEYS700GQ0 WE BOUGHT BRAND NEW AND EVERYTHING WORKS LIKE, THE BLOWER AND HEATER BUT THE TUB WILL NOT TURN. ALL THE CONTROLS ALSO APPEAR TO BE WORKING FINE. ALSO WHAT...
That is your idler pulley which holds the tension of the belt to the motor.If you have a access panel in the back of dryer than that would be the place to install the pulley.
May 23, 2008 | KitchenAid Dryers
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
Dryers Logo
221 people viewed this question
Top Dryers Experts
