Question about Whirlpool GSC9455 Top Load Washer
Water leaking from water output at top of washer
After a load of laundry is complete there is still water dripping down from the top where the water goes to fill up tub. Water is filling up tub if the water supply isn't shut off
  • wwilliams155 Dec 12, 2008
    forgot to put my model....it is Kenmore ultra fabric care heavy duty 80 series.....thing is only 16 years old and has NEVER done this before. (It really is that old and I am kidding about some of this) is this easy for a handy guy to fix. And yes....I have turned water off
    thanks
  • graciesmom1 Apr 06, 2009
    I have a Kenmore 80 series washer, model number 110.26812690. It has just started leaking/dripping from where the water fills up the drum or tub, after the load is finished. It just continues dripping into the drum. What do I need to fix this?
    President:
  • Whirlpool Master
  • 2,651 Answers
Soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Posted on Dec 11, 2008
  • Ron Coons
    Ron Coons Dec 12, 2008
    definelty an easy repair, the valve is only held in by a screw or 2, and the hoses themselves, problaby about $50 for a replacement, as far as acccessit you can find a video on you tube, simply search kenmore washerm youll see howto remove hte cabinet ,not a problem at all
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
Kenmore front loading washer model # 417.43042200 is leaking Hi, I am finding water on the floor after I wash several loads of laundry in a row. My husband took off the bottom front panel and we found...
Could be from the pump shaft seal. If so you need to fit a new pump/Also check not door boot seal is ripped or overfill from powder drawer too much water pressure...
Jan 31, 2011 | Washing Machines
Leaking water
Does not sound like a bearing problem. Check to see if water is overflowing the top of the tub during spin cycle (due to spin action) and running down the side of the tub.  Water rising up the side of the tub during spin cycle could also be squirting up through bleach dispenser opening and running down side of tub.
May 30, 2009 | Washing Machines
I am trying to fill the washer to do a load of laundry but the water is coming out the back of the washer instead what should I do
Open the washer and make sure the tube is not sitting forward .If not then you will have to lift the top of washer up and cheak for leaking hose.Also when washer is filling look with flashlight behind it to see if there is a leak there.
May 20, 2009 | GE Profile WPRE6100G Top Load Washer
Water leaking into washer
the seals where your water lines hook up are going bad.cant tell you which one though whether its hot or cold but its one of the seals
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 80 series
suspect sand/rust has gotten past screens inside water valve or screens are missing allowing residue to get into valve ..replace valve ..clean screens as needed in future but be sure to reinstall
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal De
