Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer will not agitate.
I suspect a bad belt. how do i know if that's it - pile of black residue under washer. if it's the belt how do i replace it?
  • t_cook Dec 11, 2008
    Thanks for your response. You are correct. It was the rubber isolator between the motor and the tub. We replaced the isolator and everything is working great. Thanks again for your help!
    President:
  • Kenmore Master
  • 2,651 Answers
Its amotor coupling (this machines equivelint to a belt part number 285753a) you tube has videos onhow to replace, easy enough repair(hardest part is getting off the console. and that sonly harduntil you know how it comes off
Posted on Dec 11, 2008
Kenmore model n.20912991 the belt cme off how do I fix it
Posted on Dec 13, 2008
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer agitates minimally but when you push down on agitator slightly it agitates more and is now having trouble starting to spin tub is it a belt issue?
Check out: http://www.appliance411.com/faq/agitator-dogs.shtml You can buy parts here: http://kenmore80serieswasher.com/whirlpool-kenmore-washer-agitator-cam-kit-285809/
Jun 25, 2011 | Kenmore Washing Machines
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
391 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
