Question about JVC Car Audio & Video
I have a JVC KD-G505 stereo system in my car. It's been working awesome for the month that i've had the car, but now it doesn't turn on or anything. The arial of my car does not go up at all expect when a CD is being injected or inserted after which the arial goes back down. I read a little note in the manual which said that disconnecting the stereo ofter could damage the connectors? if so what could i do to fix it?
Cerfer39
  • 709 Answers
SOURCE: jvc kd-g116 car stereo manual
here are a couple of manuals that might be right for your Radio.
http://books.jvcservice.com/booklist.asp?Model=KD-G110J
http://books.jvcservice.com/booklist.asp?Model=KD-G120J
Posted on Nov 07, 2007
cropp
  • 377 Answers
SOURCE: Change the time on my JVC KD-G405 car stereo
hi dear
you have to press and hold the set button until you see "demo" appear, and then RELEASE the set button - this gets you to the settings menu.. Then you use the little >> and << selector to select clock hour /then clock minute and use the tuning dial to adjust. - then push the set button again to exit the settings menu.
oke, plz vote me
cropp
Posted on Mar 26, 2008
zzedly
  • 300 Answers
SOURCE: how to set clock on
  1. Press and hold the "SEL" button to enter the menu.
  2. Use the "Track Forward" and "Track Back" buttons to select the "Clock H" option.
  3. Use the rotary knob to set the hours.
  4. Repeat steps 2 and 3 for minutes.
  5. Pres the "SEL" button to exit the menu.
For reference: Owner's manual
Posted on Apr 03, 2008
tech48
  • 624 Answers
SOURCE: HOW TO REMOVE JVC KD-PDR61
You slide them in on the sides of the radio in between the radio and the mounting sleeve. Push them in all the way and they open up the metal piece that clicks into place and holds the radio in. You can then just pull the radio out.
A "FixYa!" rating would be apprecieated for this free information.
Let me know if you require any more help.
Dave
Posted on Jul 12, 2008
tech48
  • 624 Answers
SOURCE: manual for jvc kd-lh811 car
You can check here for all of JVC owners and installation manuals, but your model number did not come up when I did the search for it. You may want to try using the KD-LH810 manuals, it may be the same as yours.
Posted on Jul 29, 2008
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
I have a jvc kd-r311 radio in my car which has been working for about a year now, but a few days ago it came up saying "protect" on the front and now doesn't work, I've tried pushing the...
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
Aug 03, 2011 | JVC AM FM CD DET FACE CAR STEREO
I've been trying to download a user manual for a JVC KD-LH401 car stereo but all I've found are Greek and Russian ones, help!
  • Here is the users manual you are seeking in English free of charge.
  • Hope this helps and thank you for choosing FixYa.
Regards, Tony
Jun 13, 2011 | Car Audio & Video
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
