Question about GE 29869GE2 Digital Answering Machine
How do I set the submailbox message on my GE29861GE2-A
I can't find manual and need to reset messages after unplugging unit.
I can set main message prompting to press 1 or 2 for submailbox but forgot how to do the sub messages.
    President:
  • 2,692 Answers
Your manual is available as a free download from the folllowing GE site:
http://www.home-electronics.net/ge/pc/user-manuals.asp
Posted on Dec 11, 2008
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
Stuck in standby
You can reset all to factory settings, which may help; unplug power, put back in switch on with power button. Then press together "tape", "CD" and the power button. You may need to reset the clock before it will work. If you need the manual, here is the link; http://pdf.crse.com/manuals/2048589112.pdf check page 26 for the reset if not clear - nothing else in there that seems to be related, but you may find something i missed. Hope this helps :)
Jul 01, 2007 | Sony CMT-CPX11 CD Shelf System
Message Light
The only thing you can do is unplug the unit from the wall and from the phone line. wait over night and see if this resets the unit. if it does not, I,m afraid there is a circuit problem in the phone and most likely will not be worth repairing, but try to hard reset like I said first. good luck
Jun 11, 2007 | RCA 25414RE3 Corded Phone
On my pt-50lc14 hdtv my screen is stuck on this message, 5v eeprom), 3.3v (gc2), tv-factory mode
Have you tried any of the reset commands?
Try these....please let me know the result:
Method 1
1. Unit power must be ON and unit must be in STOP mode.
2. Press and hold [CH UP] and [CH DOWN] ON THE UNIT for over five seconds. The unit will turn off.
3. Press [DVD POWER] to turn the unit on.
Method 2
1. Press [STOP, TUNE MODE] on the main unit and [>10] on the remote control at the same time for about 3 seconds until the message "Initialized" disappears from the television screen.
2. Turn the unit off and on again.
Method 3
While the unit is off, press and hold [VOLUME +], [OPEN/CLOSE] and [POWER] on the main unit at the same time for more than 5 seconds.
Method 4
While the main unit is on, press [POWER] on the main unit for more than 4 sec. (All the indicators will blink twice when the main unit is reset.)
Another possibility is to unplug the power cord......wait 30 minutes and plug it back in, possibly repeating the steps above. (Method 1 should reset the unit but maybe trying each of them may be necessary until it is reset.
The message appears to be one that displays when the unit is in a setup mode.
Thank you for your reply.
Jan 02, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Transfer unit
You need to reset the counter, instructions should have been in the box.
Jan 15, 2009 | HP LaserJet 3700n Printer
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Error code u80
Take It To A Repair Shop And Let Them Put In A Security Code Or Look Through The Manual
Feb 01, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
PLEASE REGISTER!!!!!!!!!!
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger to register.
Dec 27, 2007 | Uniden Cordless Phone
GE 29869GE2 Digital Answering Machine Logo
89 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
