Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Canon ImageClass MF6590
- How do I set fax part to print confirmation sheet after fax has gone through?
  • jenifer8 Dec 11, 2008
    THANK YOU, THANK YOU, THANK YOU!!!!!!!
  • Anonymous Mar 31, 2014
    how to receive a confirmation sheet
  • Canon Master
  • 4,338 Answers
Press the plus or minus sign to get to the "Report Settings" then press ok.
Under report settings select "TX Reports"
then set "Output" to YES
under that set "report with TX image" to ON
This will give you a confirmation with the image of you fax. Here is the manual, info on pg. 251
http://gdlp01.cwss.com/gds/0300000953/MF6500_BASIC_en_us_R.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 11, 2008
  • JDTec
    JDTec Dec 11, 2008
    You are welcome!!
Printer/fax does not print
1. have you correctly installed the printyer? if not use the sooftware cd and install.
Nov 06, 2013 | Canon imageCLASS MF6590 Copier
Canon imageclass mf6590 sucks paper back in when printing/copying even though all 2-sided print/copy settings are turned off. Can't make it stop.
You can try to put it back to factory setting's under user mode.
Press MENU and #, select clear and all, press OK.
Now the machine is back to the original state.
NOTE: after clear all you need to enter all your settings that you had before
Hope that helps!
Mar 23, 2011 | Canon imageCLASS MF6590 Copier
Canon MF6590 stuck in processing/data mode. Answers fax, but does not print. Go to copy, sticks in scanning mode. Powered off. No change.
Check whether any piece of paper is stuck. This may due to paper feeder/out roller may having the issue. Replace/repair will resolve your problem.
Thank you for using Fixya.
Jun 21, 2010 | Canon imageCLASS MF6590 Copier
Printer says download standy will not print from computer, copy, fax or print
You need to upload system software. Your copier software is broken. Call service.
Jun 17, 2010 | Canon imageCLASS MF6590 Copier
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Imageclass mf6590 will print fax but will not print from computers
Hello sir; Try to change a ethernet cable see what happen.
Aug 13, 2009 | Canon imageCLASS MF6590 Copier
Check page counter on Canon MF6590
if the control panel doesnt have the "Check counter" button then you need to print the System dump list.
Access to service mode, then go to Report, then choose report output, then choose system dump, then press OK.
All the above info is classified since this machines are not suppoused to be kept track of prints like that for the user. Reason why i cannot go further.
when the page is printed (the first one) tells you how many copies you have Totally printed... under PRINT-TTL.
good luck!
Jan 29, 2009 | Canon ImageClass MF5770 Laser Copier...
1,083 people viewed this question
old marine
old marine
