Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
GE Electric Range Model# GRSL3640TM-1- Oven doesn't heat up
Stove top, clock, timers and light all work, oven won't turn on (no indicator light) or heat up in Bake or Broil modes. When turned on self clean mode, indicator lights turned on and bottom element heated up. Tried shutting off the breaker to the range for about 10 mins, when turned breaker back on no change.
Thanks in advance for any help
Amigaman
  • 248 Answers
SOURCE: broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Posted on Nov 04, 2007
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
