Question about Proton MM2701VT 27" TV
DARK SCREEN My friend and I each purchased 21 in. flat screen Zeniths about 5 years. Picture on both has never been great, but it seems to be getting darker to the point where on some channels picture is almost blacked out. Changing settings does not seem to help.
  • les_lee Dec 13, 2008
    I have tried contrast every which way
  • 43 Answers
Have you changed contrast
Posted on Dec 13, 2008
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Dark cloud on screen of lcd tv sanyo vizon 42''
sanyo is a junk tv, and I will NEVER purchase another....less than 5 years old black clouds on the screen, repairs are cost more than the cost of a new tv.....
May 06, 2010 | Sanyo Vizon LCD-15A2 Television
My HP flat screen (crt) screen is getting dark
If the brightness control is set to maximum and the picture is still too dark, two things might be happening. The CRT picture tube may have deteriorated over time, and/or the high voltage circuitry inside the monitor is failing to deliver enough HV to the tube.
In both cases theoretically it can be fixed (the CRT tube replaced with a new one, and the HV part cleaned of dust residue and repaired), but most probably it would cost not much less than purchasing a modern LCD monitor...
Nov 22, 2009 | HP Computers & Internet
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Oliva LCD tv has developed streaks in the screen.
This is an indication of damage to the LCD panel itself. Unfortunately this can not be "repaired". The panle itself needs to be replaced. The replacement panel can easily cost almost as much as a replacement TV, so check around for pricing. You may want to try to locate another defective TV that has a good panel but electronic problems and swap the panel.
Dan
Jan 29, 2009 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Picture darker/less color/smaller until warm up
Hi there!
Have you checked for dust on the Tubes and mirror? This may cause a bad picture quality. Also power supply related problems like capacitors can cause a dark picture. Try replacing some of them in the power supply area and line stage.Also adjustments in the service mode,but for this you will need the service manual. Good Luck,JUS004
Oct 15, 2007 | Mitsubishi VS-55707 TV
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Mar 03, 2007 | Zenith Z27X22D 27" TV
Proton MM2701VT 27" TV Logo
47 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
