Question about Sharp AR-M700N Copier
I need part numbers for Sharp AR-m620 fixing unit cleaning rolle
I have a fixing unit that has new style fixing cleaning rollers instead of
the old oil roller and cleaning grid & felt. I only have the part number for the old cleaning roller kit (700RC). I need the part numbers for the modified cleaning rollers
  • Sharp Expert
  • 1,326 Answers
The part number is DUNTW7305DS88, DUNTW7305DS80,DUNTW7305DS11, DUNTW7305DS15
Not really sure which one is right - I found the part number on
Precision Roller.com they have only one part number on there web site # H3164 It cost $595.00 if your not a vender.
Posted on Dec 11, 2008
How do i clean the heater roller
the top roller is teflon coated and cleaning wont help much if the coating is damaged it will need to be replaced. if it is the lower roller you will have to clean it with a rubber reconditioner but you must wait untill it is cold and make sure it is dry before starting your copier again. you are best just to replace the rollers instead of cleaning them. if the toner is sticking now cleaning will only help for a short time.
Jun 24, 2014 | Sharp AR-M277 Black and White Copier
I Have Sharp Photo Copier AR 5316 when i given Print command the image was good but background double image was also come pls sir give some urgent tips sir
Needs a fuser hot roll. Once the get worn, they pick up some of the image and reprint it on the page.
They are available form several sources, Kaytin comes to mind. Precision roller. Google the printer model number . I would google is like this. Sharp AR 5316 hot roll.
That should give you several sources, Honestly I would replace the press roll also. Probably you should be able to find them both for less than 100 dollars, I sure wouldnt pay more. Look around. You can find them for a decent price. You may even want to look on E-bay. they often have them there.
Aug 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower...
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Feb 06, 2010 | Sharp AR-M700N Copier
Start up Copier Sharp AR-M620 fail L4.03
Sounds like one of the motors is seized.Check that you do not have anything stuck in any of the rollers that may stop the rollers from turning correctly.
Nov 01, 2009 | Office Equipment & Supplies
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M700N Copier Logo
171 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
