Question about Mitsubishi WS-55511 55" Rear Projection Television
Format stuck on Mitsubishi WS-55511 Rear Projection TB
Help! I know I shouldn't keep the format of the screen on 10801 standard because of the gray sidebars and burning those images into the screen. My format on my WS-55511 Mitsubishi rear projection TV is stuck on standard format and I can't get it to go widescreen, stretched, or any other way. I have tried shutting it off and turning everything all back on, but to no avail. Restarting it all and unplugging everything didn't set it back to default or anything. I have got to get my format to work so I can see widescreen, etc. Any suggestions? The Woodster
    Novelist:
  • 192 Answers
Normallly, if the format button on the remote does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on Mar 04, 2007
Black vertical bar on right side of screen
ws-55511 Model?
If so, look with set on a not used video input to see if can see discoloration there also---also look other side for it.
Let me know what you find. Answer is based on model number given.
Apr 30, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How do i reset my mitsubishi television model#ws-55511
First a reset may not help unless I know what your problem is.
If model listed (WS-55511) IS CORRECT: set has 3 hidden menus:
Option Menu (hard reset of all settings to factory)
Technical Menu (Adjustments for various things)
Convergence Menu for adjusting convergence.
THESE ARE NOT ACCESSED FROM CUSTOMER MENU. Each requires Mitsubishi remote and a 4 digit code .......
So, What is your issue with the set?
I have the codes but it depends on model number and what problem with set is, reset is in Option menu but will not cure all problems.
SD TECH
Nov 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Returning to "streched" picture as top of heads
Remote control is needed to change aspect ratio. The button on the remote is labeled format. Standard definition sources have six picture sizes and HD has two.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws 55311 format issues
Apparently I did not have the correct remote to go with this television. The remote I had was a Mitsubishi, but I was able to obtain one that had the 'format' button.
Jun 21, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Picture doesn't fit screen
If you haven't tried to change the format yet, try that first. Most of these tv's have a wide range of options from full to wide to split etc. Stretch would probably work in most hd formats.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Format control
Press the format button on the remote.
Nov 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Moving a WS 55511 downstairs in my house
Do you have friends? If so, call them and get help.
Apr 12, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
