When I push the on button it shuts off imediately.
When I push the power button on it imediately turns off. is there a reset button I need to look for?
  • 20 Answers
You may need to replace your Tvs convergence board. Go to www.partstore.com and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace.
Posted on Dec 11, 2008
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
VITO TV turns off imediately after power button is hit
you need to replace your power supply board.
www.shopjimmy.com
Jan 21, 2013 | AOMNI Corporation New Universe Technology...
Key stuck in ingnition
If your battery goes dead, the ignition locks the key in ignition switch. You put a new battery in and you'll be able to remove the key
your anti theft system may be enabled. Did you play with the power door locks before starting
Under the ign lock assbly there is a small plastic plug... pop the plug out and stick a small screw driver in...u should imediately feel a spring load button in there. Push up with the screw driver and turn key back, it will come out.
Dec 24, 2011 | 2003 Chevrolet TrailBlazer
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Apr 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How do I reset the Change Oil Indicator where the odometer is located. 2006 Explorer
1.) Press the TRIP/RESET button to cycle to "SETUP MENU HOLD RESET".
2.) Now press and hold the button for 2 seconds until "RESET FOR SYSTEM CHECK" is displayed, then release.
3.) Imediately press and hold button for 2 more seconds until "Oil 100% RESET IF NEW" is displayed, then release.
4.) Imediately press button once to display "HOLD RESET IF NEW OIL" and release.
5.) Imediately press and hold button for 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Sep 10, 2009 | 2006 Ford Explorer
My C120 will not shut down using the red power off button
When you turn on the breaker switch push the nearest grey button to the powerbutton than you get a factoryrest your software shoud be 4.29
Jun 29, 2009 | Raymarine C120 System Pack C120 Raystar...
Power button won't shut off
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
