Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover Floormate H3000 replace water intake hose
Ordered the part can't figure out how to take it apart to replace the part!
I have the same model with a broken water recovery hose. I can tell you how to get the old one off. Would you tell me Hoover's name and part# or item# for the part? I'm not sure I have found the right name or part number to order...
Remove the recovery tank. Remove 2 screws behind the recovery tank that hold a plastic cover on the collar connecting the recovrery hose to the "flat" plastic channel mounted behind the recovery tank. Remove the front nozzle and the brushes. Remove the grey outer cover from the top of the floor head section by prying upwardd on the front of the grey cover. Remove the plastic tie strap from around the recovery hose, water delivery hose, and the cable that runs up the length of the handle to the button that turns the brush motor on/off. I was able to "relaese the locking mechanism" on my tie strap and remove it so I think it is reusable, but you may have to cut/break yours then replace it on reassembly.
Now you have to unhook the front of the wheel assembly so it will swing down out of the way. This will be easier if you set the Dry/Wet selector to "Dry Pickup". To unhook the wheel assembly: (1) Dissconnect the cable associted with the brushes by pulling the black ball on the end of the cable upwards and out of the small black rectangular plastic connector. You'll probably also have to pull the cable's outer sheath upwards out of the channel it rests in. (2) Look directly behind and below where that ball was connected to find a small black post around which an arm is fastened by an elongated hole on the end of the arm. This post is designed to "pop" in and out of palce. (3) Using something like a pair of needle nose pliers, pop the post out by applying pressure toward the side of the head that has the Handle Release lever. (Be carefull not to drop and loose this post as I almost did.) Now from beneath the head, with a little force and some wiggling you should be able to pull the front of the wheel assambly downward so it swings out of the way.
The best way I can think to describe the next steps is if you look at the new part you'll see 2 tabs sticking down from the bottom of it with slots in them One tab hooks on a bump in the aqua colored plastic just behind the black Brush Motor housing and one hooks on a similar bump just forward of the Brush Motor housing. Looking at the head from the bottom, the rear tab is easy to see. To see the front one, look for a small slot in the aqua plastic. Reach a small screwdriver in from the bottom of the head and pry these tabs off the bumps while applying some pressure on the old recovery hose part (the rear tab goes to the rear and the front tab goes forward). I broke both tabs off my old recovery hose part and luckily didn't do much damage to the bumps. Once you release these tabs the part should be loose from the head.
Now press the Handle Release to tilt the head down in a typical operating posoition and you should be able to pull the hose connector down off the "flat" plastic channel and out toward the front of the machine. If the new part does not come with a connector on the top end of the hose, you can unscrew the old connector from the old hose (turning the opposite direction of normal threads) and srcew it onto the new hose.
Posted on Jan 12, 2009
Ho do you replace the floor hose on a h3000 floormate?
Hello! The water channel hose is no longer available. You may be able to locate the part through a vendor online or through an authorized service center. The part number is 59177042. I have included a link where you may go to locate a service center near you. Service Center Locator
Hope this helps!
Aug 03, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate--Does not pick up water.
First make sure that you are getting suction from the bottom of he machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
Feb 07, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Oct 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Water Uptake Hose Split
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=602269
Posted by jre8655 on May 16, 2008
How do you remove and replace the Water Uptake Hose Assembly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate stopped picking up the water
Usually when this happens, it has to do with a dirty or bad filter(#45, 40112050). Or the recovery tank isn't seating like it should. Maybe this picture will help.
Feb 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
2,078 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
