Question about Mitsubishi WS-55805 55" Rear Projection Television
Same as above
  • 20 Answers
You may need to replace your Tvs convergence board. Go to and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace.
Posted on Dec 11, 2008
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
TH42PZ85U Panasonic that will turn on for a couple of seconds, not even long enough for picture, then it shuts off. Red power light blinks 2 times with about 3 seconds in between the 2 blinks. I am...
1. Reseating the connector P25 may solve the problem. If it does not.
2.Right before the unit shuts down, check the VSUS voltage at connector P2 of the power supply. If VSUS voltage measures zero volt, disconnect the connector P2 and SS11. Check the VSUS level at socket P2. If it is still low, replace the P board.
3. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
4. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Jul 09, 2007 | Mitsubishi WD-62327 62" Rear Projection...
TV not staying on
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 12, 2006 | Panasonic PT-51HX42 51" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
