Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Today I notice that my Fridge was at 58 dgrees and the freezer was at 0... I unpluged the unit waited 10 mins and plugged it back in to reset the unit and the temp in the Fridge Section has climbed to over 80 degrees per the display, it is warm in side. Any ideas on what is causing this and how to test/reset the issue? Mark
  • Anonymous Mar 26, 2014
    food side is around 50 degrees and freezer side if real cold the crossover vent is full of ice freezer runs constantly
    President:
  • 878 Answers
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Posted on Mar 04, 2007
  • Ron Marek
    Ron Marek Mar 06, 2007
    Let the mental midget who rated this poor come up with the right answer. So much for trying to help some people.
Same for me, the fan assy in the freezer, however it's not just a fan it's also a control module of some sort. Also, the guy knew exactly what was bad and had it in his truck.
Posted on Jul 24, 2007
Catriver....Exactly right..The Sears guy came by, as well knew of this issue and replaced the Bad Fan motor assembly and now 33 degrees and happy...
Posted on Mar 06, 2007
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
I bought kenmore trio bottom freezer 2 years old, everything works fine, until one week ago, the fridge part becomes freezer, it frozen all the food, even I set temperature to 45F on the fridge.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 22, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Just today the refrigerator part of our refrigerator has lost its ability to stay cold. The temp inside is 58 degrees. The freezer part seems find. any recommendations.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 03, 2011 | Refrigerators
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
442 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
