No sound when playing DVD's
There is no sound when playing DVD's. When watching TV, the sound is great. This only recently started and it is intermittent. Some times the dvds will play just fine and then the sound cuts out or it won't have any sound at all. This a Panasonic SA-HT720 that is about 5 years old.
  • pat31477 Dec 12, 2008
    Thanks for the help but it still isn't working. I even went as far as contacting Panasonic but it looks like I will be buying a new system. Thanks again for the timely answer.
    President:
  • 624 Answers
Does the display still show the time on the DVD as if it is still playing? Or does the time display stop? If the DVD is still playing, you still see the movie going along with no sound, then the problem is in the DVD module board if you are also listening to the tV thru the Panasonic.
The amp is located in the sub-woofer and if the sound is good thru it when using the TV it only leaves the DVD module.
The part number for that part is REP3454G
I am not sure this board is even available. But that is the part number.
It would be a difficult task to determain what components on that DVD module board is bad. I have repaired a good number of these Panasonic systems working at an authorized service center. If you have the right tools, a multimeter and the schematics, I can help you to figure out at component level what is bad. But without those tools and a decent knowledge of electronic components this would be a useless effort. This is a very complicated circuit and could have a good number of different reasons why it cuts out only on the DVD player.
Your best choice would be to take it to a service center for repair, unless you think you can troubleshoot it yourself.
Posted on Dec 11, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On your Panasonic SA-HT720 Home Theater intermittent audio:
  • internal check of the components/boards for any loose connection/cold solder;
  • possible heat related component failure primarily on the capacitors;
  • if for whatever reason, the repair would be required, pls consider the cost;
  • it might be more to your advantage to shelve the repairs and simply purchase an external DVD player to be hooked up to the Home Theater;
  • should you consider a DIY (do-it-yourself), a Service Manual would be invaluable.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 11, 2008
    Since this is a Home Theater with built-in DVD and 6 speakers, the TV connection and the cables would be least likely issues.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 728 Answers
You may either have a short in the sound aux cord running from the dvd player to the tv. Check that cord and try getting a new one and see if that solves the problem. If it does not, then make sure all of the connections are firm and in the right place. If that still does not help, you may have a problem inside the dvd player with either with the laser that reads the dvd's for sound and video, or you may have a problem with the part you plug the sound plug in to. There might be a short in either of the connections. If you are not good with electronics, then do not open it your self. Get it checked by a professional.
    President:
  • 2,110 Answers
Try to check thecables connecting to TV from Home theater..it may be loose connection..
    Master:
  • 479 Answers
It could be the problem with the wire connecting from dvd to the tv replace the wire.and also it could be the problem of the device internally and needs servicing and cleaning.
"WARNING STOP WATCH WATCH VIDEO" and no sound
Follow the following steps to overcome this problem:
  1. Locate the "Brake" wire (usually the pink wire).
  2. Connect the "Brake" wire to a negative point, e.g. body of vehicle.
  3. Test by playing a DVD and your problems have been solved.
Sep 24, 2009 | XO Vision XOD1735 Car DVD Player
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
I can't get any sound from it.. just great visual...what can I do?
Yellow plugs and jacks are the Video and that works. Red and White are the RCA sound wires from the DVD to TV.
OR
Your sound goes from the DVD to TV via a Fiber Optic or Fire Wire.
OR
You use Ch 3 on the TV and watch the DVD through a TV Tuner and use the TV Antenna Cable between the DVD and TV.
If that didn't help, let me know for more things to check like Audio settings on the TV.
AL
Apr 26, 2009 | Televison & Video
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
DVD Player Subjective to Netflicks Discs...
Glad you have the problem straightened out.
Have a great week
Ed
NC Electronic
Mills, Wyoming
Jan 10, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
55 people viewed this question
 Grubhead
Grubhead
