Question about EliteGroup K8M800-M2 Motherboard
Can't see anything on screen on bootup (nothing wrong witt screen
Motherboard: K8M800-M2
HD: 1 80G
RAM: 2 x DDR 512MB
2 DVD RW
1 floppy drive
OS: XPPro
When computer is switched on, fans go on, but no response on screen. Tried with same results:
1. swapping RAM with same results,
2. alternative graphics card,
3. unplugging peripherals (HD, DVDs, floppy)
  • Anonymous Dec 11, 2008
    Thanks for looking in, jshtate. I did do that, but unfortunately I can't remember where they go now. How could I replace them in the right places? The only info I can find in the manual is where to put the Clr_Cmos jumper, and I've done that.
    Cheers
    Eric
  • Anonymous Jan 26, 2009
    I'm using mine with Windows Home Server. It was working fine - there was a microsoft upgrade - reboot - nothing. Same results as Spork7.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 56 Answers
Did you change any jumpers on the board
Posted on Dec 11, 2008
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    When i connect a sata hdd, it says install successfully but it wont initialized.. what should i do?
    try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
    good luck
    Sep 05, 2010 | EliteGroup K8M800-M2 Motherboard
    Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
    You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
    If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
    Sep 02, 2009 | Computers & Internet
    I have tried to install OSX 10.3 on my PowerMac G3. It has a DVD-RW, 512MB RAM and a 20 GB HD. I hold the C key like I should but it won't boot the CD. Any suggestions?
    Troubleshouting
    1. The DVD drive is not working
    2. You have not set the boot sequence on the computer for starting with the DVD drive
    3. the DVD is damaged
    4.The OSX require a newer motherboard
    Hope thats help
    Aug 25, 2009 | Apple Computers & Internet
    USB driver 2
    Can you be more precise? You don't need USB driver for this PC...
    Jun 25, 2009 | Gigabyte Computers & Internet
    DELL OptiPlex GX150 Upgrading
    The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
    The Socket 370 was a design used only for P3 processors.
    Max RAM for that system is 512MB no way to upgrade past that.
    If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
    Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
    Crash with ram
    you need to remove that the new ram
    too much for the system
    then restart
    Jan 21, 2009 | R.A.M. Computers Aqua Computer Aquagra FX...
    Pc died
    Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
    Hope this helps.....
    Tony.
    Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
    ECS K8M800 bios can't detect hd pata seagate
    How you setting the jumper, pls refer to mobo manual book or HDD or your DVD/CD recorder. i gues your problem is in setting the jumper. thx
    Jan 31, 2008 | EliteGroup K8M800-M2 Motherboard
    EliteGroup K8M800-M2 Motherboard Logo
    175 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
