Question about Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
What does this mean????? It came when i tried to start a load of laundry all the lights flickered on and off like the power was going out. Flashing F71 (i swear thats the number but I cant find anything like that anywhere online) and now it wont start at all.
Please Help!!!!
  • 26 Answers
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
What does error code f71 mean?
F71 means it is an Central Control Unit(CCU) communication failure.
http://www.fixya.com/support/r6709094-whirlpool_duet_f70_f71_error_codes
There is an detailed article by one of our senior experts in the above link.. Kindly look into the same.
Mar 03, 2011 | Kenmore Elite 45986 Front Load Washer
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Dec 11, 2010 | Kenmore 47081 Front Load Washer
What does an F70 and F71 error code mean?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Nov 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F71 mean ? This comes up half way through the cycle
Regards.
Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F71 error - no other keys work - Duet Steam Washer
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F70 & F71 Codes are showing up. Washed sa load last night, no problem. Won't start and no control lights
Aug 22, 2009 | Kenmore Front Load Washer
Kenmore Elite H3 Error Code F71
The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
Jul 31, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,040 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
