Question about Motorola Mobility V360 Cellular Phone
When I open phone the screen lights up but has nothing on it .
When I close the phone the display on the outside works it said something about transmitter locked
  • 1 more comment
  • sherry724 Dec 11, 2008
    the phone is a motorola pininfarina
    the display on the inside lights up but does not show anything
  • Anonymous Dec 12, 2008
    i want to connect the phone to the internet but con not
Dfgasf
Posted on Jan 06, 2009
The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Apr 06, 2012 | Nokia 2720 Fold Cell Phone
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
My motorola v557 cell phone doesn't light up. how
Good luck.
Jul 12, 2010 | Motorola Mobility V557 Cellular Phone
Washed phone
Good luck.
May 19, 2010 | LG enV VX9900 Cellular Phone
Inside screen when black and the outside sreen was still working then it went black my phone still works like normal just the screens are black and i cant see anything
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
Good luck.
Apr 16, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Inside screen is blank; keyboard and phone, outside screen all working fine. inside screen used to be able to be reset by closing and reopening but now nothing makes a difference. Have powered Off/On...
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Nov 08, 2009 | Cell Phones
Something is wrong with the display on my Kyocera Strobe K612B. When I open and close the phone sometimes nothing happens but sometimes one of the screens gets distorted. The outside screen is usally the...
This EXACT same problem happened to me and I had to pay $50 to some cell-phone repair guy to replace the whole front piece of the phone....I HATE Kyocera and will NEVER buy ANYTHING from them ever again!
Aug 15, 2009 | Kyocera Strobe K612B Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 Cellular Phone
Ok so when I close my phone I still see the time and my background picture but no light immanates (hope I spelled that right)from the screen if thats what your saying that's normal. Now as far as the inside screen if you dropped it the connection that lets the phone know it's closed may be jarred lose and offset (not sayin u dropped it)although you say it dims. When you close your phone the inside screen should turn white and then turn off just barely have your phone open to check, if it does this then the connection is working. And you need another opinion.
Dec 07, 2006 | Motorola Mobility RAZR V3
Motorola Mobility V360 Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
